joetx
- Joined
- May 4, 2014
- Messages
- 37
- Location
- United States Falfurrias, Tx
- Occupation
- buy, sell, build hotrods, retired
Hello guys, new to this forum. Own a hot rod shop, but use my 1996 case 1840 a lot, as I work alone and can't do what I used to be able to do....Have been doing some reading, but not finding the info I need. Never had a problem starting my 1840 until this week. Used it about a week ago and worked fine. Tried to start it and saw that the fuel gauge didn't light up. Turned the key and nothing. Completely dead. No click from starter or fuel solenoid etc. So I hooked up the battery charger and still no power.
Disconnected the charger and jumped the starter solenoid and it cranked. Had someone sit in the seat, key on, (no light indicators on) and jumped the solenoid again. It cranked but it didn't fire. This machine always starts on the first couple of cranks. So my ground and battery are good. Don't know where the fuses are if any...
Unbolted the instument panel and disconnected the ignition switch plug and had some corrosion, cleaned it, tried it again, nothing... Ran a jumper wire from the batt to the hot terminal on the ignition switch plug, then jumped the plug to the other plug wires with a small wire. When I did that, motor cranked, but never got the fuel to light up. Reconnected the plug to the switch and again jumped the main batt line direct from the battery and used the key. System is dead. Will not crank with the key or light up my gauge lights.
There is a small square about 1"X1" next to the ignition switch, don't know if this is a switch or a relay. Any help will really be appreaciated. Thanks, Joe.
