justsomedude
Hi there
I've recently brought my machine (2010 cat420EiT) back from a site it was being used on and while going through it i ran into something i don't understand.
when looking at the hydraulic oil sight glass to see the level it shows nothing. not even below minimum. just looks totally empty yet all functions are working. So i went and bought and poured in a 5 gal bucket into the filler tube with the blue plug in it. Still the sight glass shows no level at all. No puddle of oil under the machine after pouring the entire bucket in. Hydraulics seem to operate but haven't tested them with a load. Machine will drive forward and backwards seemingly with no issues but I've only moved it a short distance.
When i check the transmission oil the dipstick seems to show it as very over full and the fluid is clean and clear like the hydraulic oil i just poured into the hydraulic tank.
Question 1: Is there a condition by which hydraulic oil can escape the hydraulic tank and get into the transmission somehow while not even running? 5gal of oil is a lot of fluid to escape instantly.
Question 2: Is this machine ok to drive (im assuming its not)
Question 3: is this machine ok to use the hydraulics (im assuming not)
Question 4: if the answer to question 1 is yes is that an expensive fix?
I'd appreciate any insight anyone could share with me.
