no fuel pressure 3406
Discussion in 'Trucks' started by Beetle_Spin, Sep 26, 2022.
  1. Beetle_Spin
    Beetle_Spin Active Member
    May 8, 2022
    36
    south east texas
    im haveing trouble getting fuel pressure on my 99 3406 2ws i got a gage and i can get it up to 5 psi with the hand pump after a while of pumping but once i turn it over to try to get it to build pressure i lose it all instantly new fuel lines new transfer pump new filters and new fuel regulator valve any ideas im about to check the injector o rings soon also the primary fuel filter will get sucked almost dry every time i turn it over
  2. Truck Shop
    Truck Shop Senior Member
    11,090
    star gazer
    SE Washington St
    There are check valves in the filter base and there is a check valve in the primer pump, those need
    to be checked first. If the one in the primer goes bad/rolls it won't start.
    Oxbow likes this.
  3. Beetle_Spin
    May 8, 2022
    36
    south east texas
    i changed the check valve thats on the bottom of the filter base but there is another one in the hand primer itself ?
    Oxbow likes this.
  4. Truck Shop
    11,090
    star gazer
    SE Washington St
    Yes.
    Oxbow likes this.
  5. Coaldust
    Coaldust Senior Member
    May 9, 2011
    2,208
    North of the 60
    Yeah. Sounds like a primer pump issue.
    Oxbow likes this.
  6. Cmark
    Cmark Senior Member
    Jan 2, 2009
    2,965
    Maybe 20 years ago there was a batch of hand primers where the rubber piston would break up and block the outlet. I would have thought that they would all be worked out of the system by now, but you never know.
    Oxbow likes this.
  7. Coaldust
    May 9, 2011
    2,208
    North of the 60
    My how time slips by. I remember that. Seems like the latest ones are cheaply made and leak prone out of the box.
    Oxbow likes this.
  8. Truck Shop
    11,090
    star gazer
    SE Washington St
    Only other time I've seen the filter sucked dry {6TS 3406} T-800, the sending unit fell to pieces and
    blocked pickup tube in tank. As soon as engine shut down the piece would float away, start back up
    then die at sporadic intervals. It was a fun one to troubleshoot. Had plenty of fuel psi.
    Oxbow likes this.
  9. Beetle_Spin
    May 8, 2022
    36
    south east texas
    heres a update these hand primers are junk had 2 break right out of the box back to back. But got new fuel lines and i pressurised the tanks and used the hand pump and got about 20 psi on a gage i hooked up.Had someone come over and said the fuel transfer pump was on upside down ? so i fliped it when we spun it it was sucking air out of the line that pushes fuel into the system. He also said i was missing a battery cable to the starter only have 1 main wire from the batterys said i need 2. Hooked jumper cables to battery amd starter and it turns over great just still no pressure. it seems like the hand pump is working but then agin the past 3 new ones iv gotten have literaly came apart as soon as i use them.
  10. Beetle_Spin
    May 8, 2022
    36
    south east texas
    Also took apart the entire fuel system and blew all the lines out and pulled injectors to discover one had a broken spring.
  11. Beetle_Spin
    May 8, 2022
    36
    south east texas
    Im gona make a new cable for the battery and instal the old primer pump that i origonaly took off the truck to see if it still works. its sucking when i hold it aginst my hand so only way i know to see is to try it out. Cant see it causeing any more harm seeing im struggleing to get any psi i normaly get about 2 or 3 psi right now with the hand pump on it then lose it all when i turn the truck over
  12. Oxbow
    Oxbow Senior Member
    Nov 22, 2012
    885
    Idaho
    To expand on what Truck Stop said, there are two check valves in the primer pump base, each about the size of a dime. If they look identical one has flipped over.
    Likely not your problem as you have tried other primer pumps, but it only takes a few minutes to check them.
    Truck Shop likes this.
  13. Beetle_Spin
    May 8, 2022
    36
    south east texas
    makes sence ill pull it off ans look
  14. Beetle_Spin
    May 8, 2022
    36
    south east texas
    i changed the primer it definetly seems like that was part of it but i broke the gasket so have to make a new one tomarow also added the extra power cable and she turns over like it should just have to prime it now becouse it burped a few times with what fuel was in the injectors can anyone explaine the proper way to bleed the system
  15. Beetle_Spin
    May 8, 2022
    36
    south east texas
    has anyone ever seen a transfer pump flow backwards mine is pushing air from the sucktion side and sucking from the push side seems like i got a faulty pump
  16. Cmark
    Cmark Senior Member
    Jan 2, 2009
    2,965
    What's the part number of the pump?
  17. Beetle_Spin
    May 8, 2022
    36
    south east texas
    id have to take a look tomarow
  18. Beetle_Spin
    May 8, 2022
    36
    south east texas
    033022 0010 384-8612
  19. Cmark
    Cmark Senior Member
    Jan 2, 2009
    2,965
    That is a rear timing case mounted pump. Is this what you have?
    What's your serial number?
    Oxbow and Truck Shop like this.
  20. Oxbow
    Oxbow Senior Member
    Nov 22, 2012
    885
    Idaho
    If I'm not mistaken there are two rod lengths for those transfer pumps.
