Thought I'd share in case anyone has the issue.
Air ride would deflate.
No seat heat. Blown fan fuse.
After reluctantly pulling the seat. Not horrible. But not fun. Turned out I had an unwelcome guest living under the seat. Chewed through several wires. Was shorting out the 20 amp heater fuse.
Got those all soldered and cleaned up.
Found the air leak. A cracked fitting. I'm not positive that's the only one as its the hose out of compressor, before the fill valve. Only makes sense if the whole system remains charged. But ill grab a compression fitting tomorrow and reinstall. Also steam cleaned the seat while it was out. To rid the cab of 3000 hours of fart ghosts.
