bigteddy5b
First thread here, couldn't find another like my issue. New Holland C232 skidloader, driving across corral, chugged then died. Cranks, no start, tries to smoke some but won't run. Shows a code of 3835 on the info center, Throttle valve actuator circuit- low error (power stages). Hooked battery charger up but still shows that code. First though was fuel problem as it chugged then died.
Changed fuel filters, reprimed fuel system, still tries to fire and there's a little bit of smoke. Running on little sleep and lots of frustration, pulled air filters and gave it a sniff of ether and it wouldn't even fire on that.
I'm almost wondering if the TVA went bad and is closing off air to the engine. That would kind of cover why it won't fire on ether too.
