Nh 220 injector push rod trevel distance
shanbhai
Pakistan
Dozer D 80 12 A
NH 220 engine shop manual need only injector and valve setting and injector plunger travel in mm any one sends me
Simon C
Heavy Equipment Mechanic
Think the injector is done on the same pulley marking as the valves. Injector set at 55inch pounds first, followed by valves on same cylinder set at I believe maybe ).024 thousands. May be able to find more on it .
Did one about 1 year ago. That was how i did it. Ran very well.
tctractors
Worc U.K.
As Simon C has quoted the injectors are set down in Inch Pounds off the ABC marks on the side pulley, check your C.P.L. plate for the settings that is on the front gear chest nearside, also always check the valve springs as its not uncommon to see a few broken, don't use the Truck engine service book as they are usually set at 70 inch pounds, if the injectors are set to tight it will be hard to start, to loose and the Sky will be dark.
shanbhai
Pakistan
I understand injector torque I want to know about injector push rod trevel distance 4mm or 5mm etc standard travel nh 220 for example nt 855 injector trevel 5.79mm what is nh 220?
shanbhai
Pakistan
Ok I want to know about injector trevel distance how to increase and decrease on cam followers any one knows about this
Simon C
Only person that I know on this foum is " Truckshop ". He knows how from what I have read. I do not have manual, where I did my exact same last job they had the manual on NH220. It was on a D85 Komatsu dozer. Send him a message and maybe he can respond.
Simon C
shanbhai
Pakistan
Simon C
Ok thanks
