Kvwranch
Hi all, new to the site and new to Hitatchi excavators. I have a Hitatchi 120-2. We have experienced some problems with it from day one and it has developed some new problems lately. The first problem is the jib or dipstick, it is very slow unless you curl the bucket all the way in or out and hold it there then it moves faster. The second problem is the stepping motor? It will sometimes go to full throttle when you go to start it or won't move up to idle and won't start. If you cycle the key and watch the throttle you can get it to work and it will work all day if you don't shut it off. Back the the jib today when I was running it I wiggled the wires on the two sensors on top of the pump and now everything is moving slow and the jib is even slower. Any help or info on these machines would be greatly appreciated.
