Well I guess it's good I got the new foam filled tires for the grader last fall. I went out to check on the property and I expected 1 flat tire but had 2. Too bad I couldn't have got them installed already. It's a fairly big job to remove the existing wheels, mount the adapters and then mount the new wheels. I haven't decided yet if I'm going to remove the studs from the hubs and use bolts on the adapters or leave the studs in place incase I want go back to the stock wheels or at least have that option.
