New toy!
colson04
Delton, Michigan
Just bought this at an auction, today:
https://www.harborfreight.com/7-inch-x-10-inch-precision-mini-lathe-93212.html?_br_psugg_q=lathe
OK, so its chinese HF junk. I paid an American auctioneer for it, and I think it'll do the little stuff I have in mind for it!
Anybody wanna play gue$$ what I paid for it?;)
$50?
I'd like to have a lathe and mill at home, but I just don't have the space for them today. I've looked at the Harbor Freight specials, Grizzly, and some really old (60+ years) Clausing and Bridgeport equipment. I need to build another barn first, then I can fit it out with a shop.
56wrench
alberta
In my opinion almost any kind of a small lathe is a good starter machine. The tooling and accessories can cost as much or more than the machine. There are some good machinist's handbooks that are invaluable. Also some u-tube videos. Tubal cain has some. One i like to watch for big stuff, is Cutting Edge Engineering from Australia. The principles for small stuff are much the same. I'd like to get a milling machine and a bigger lathe but at this point in life its hardly worth it.
DIYDAVE
MD
Well, I'll spill. I paid $30. I think the saving grace that let me get it that cheap was that there was no cell phone reception at the sale, so no one could search the internet for the item number. the one area of concern with this one is that the feed drive is cog belt and plastic change gears. I put it together, today, easy job. Tried it out on a small bushing, the 5/16 tooling rides a little high of center, so I'm gonna look for a 1/4 cutting bit, or put a penny under the rear of the 5/16 bit, but that's tomorrow's job...;)
DIYDAVE
MD
Well, I dug up a coupla 1/4" cutter bits, Man that little thing pulls a a pretty little 20 thou shaving! Might do 30 thou in mild steel, but since I didn't want to shoot the bushing I was workin on across the room, I kept it to 20, max. I don't have a cut off holder for something this small, I did find a 5/16" cutter with a cut off grind, slipped a dime under the back of it, clamped it in, and it cut the bushing in half real nice. I'm sure I will find more work for it... Even at the 20% HF discount price, I think it would be worth it. Now to watch some more auctions for a QC tool post, and a cut off holder!;)
DIYDAVE
MD
At my age I don't fall down many. I used to subscribe to home shop machinist, in my younger days, Made several projects on the old Smithy mill/drill, that I still have. I aint gonna spend $ like I did, back then...;)
hosspuller
North Carolina
From reviews and examples in HF store I've seen, take it easy with the rough cuts. You don't want to break those plastic gears. It's not a Hardinge tool room lathe
DIYDAVE
MD
Well, I got the first project done. Cut a bushing to fit a cut-off from a 15/16 carbide hole saw(just some nylon stock, that was about 1-1/4 thick) JB welded the steel bushing to the tip of the hole saw cut-off, took the center drill out of the hole saw, used a slightly turned down 1/4 X about 3" bolt, so it would slide through the cut-off and into the pocket hole, where the drill had been. Put it all together, and used the set-up to drill a 7/8 hole out to 15/16. The cut-off and bushing serve as the guide, so the hole saw won't wander. Was drilling out holes in lawn mower blades, so they would fit my mower.
What I learned about the lathe: 5/16" tooling is too tall for center, 1/4" tooling is too low for center. I shimmed the 1/4" tool bits with some plastic off of them damn blister packs that almost anything is packed in. A QC tool post for it will be nice, If I can find one priced right. I would recommend anyone look at the videos on youtube, these little lathes are pretty popular. As I am not using it for any production runs, just puttering around the shop, I can put up with its quirks, specially for the $30 I spent on it!;)
DIYDAVE
MD
Raining here today. So I had some time on my hands to fix a nagging intermittent problem(I hope!) got a seeder drive belt jumping off every once in a while, due to a small diameter idler that runs on the back side of a belt. Every once inna while, it hops off the idler, always along the outside edge, so I figgered i'd build up that outside rim, some kinda way. Rooted through the bushing and washer bin, found a rather odd looking piece of aluminum. About 3/16" larger in diameter than the idler. It had a half diameter piece that needed to be removed, then the whole thing needed to be turned down, so's it would nest inside the pulley, with just a lip, sticking over the rim of the idler's rim. Anyway, this thing also had 3 1/4" holes already drilled through the thickness, evenly spaced, so I could drill through the pulley, to mount it. More on that, later...;)
Turned the hump off the piece and got it to nest into the pulley, but the pulley's bearing stuck out about 1/4" so I thought, WTH, I'll bore the center out, a little to accommodate. Went up to the other lathe to borrow the boring bar, bring it back down, MT3, this one's MT1 or 2! Crap, now what? Turnt the tool post removed the bit, looked, other end was ground on the bottom side, enough to use it in the tool post, as a boring bit, so that problem is overcome! Got it bored, fit nice and tight lip snug to the side of the idler. Now back to them 3 holes, checked, they just fit on the 1/4" flat area of the idler pulley, between the bearing and outer lip of the pulley. OK, but man this 2 piece spot welded idler is thin, my guess 1/8-3/16" thick where I wanted to drill the bolts through! Also that flat spot is so thin, if you put ANY bolt through, you'd never get a nut in behind the pulley! ;)
OK, so thread it, fine, of course. Found 3 #10 fine thread bolts, that might do the job, put the piece I made in place, used the 3 holes in it as a template, started al 3 with a 1/4" bit, to mark the spots to drill, used a 5/32" to drill the holes, cause that's what I had handy! Anyway My eyes ain't as good they usedta be, so All I knew about the bolts I had, was that they was 32 tpi, so went over to the other shop, got 2 taps, 1 a # 8 and the other a #10. tapped with #8, too small, GRRR. Didn't even drill out the holes, just tapped right through with #10 screw. Put bolts in, a curly red hair too short, GRR, again! walked over to the other shop, again hunted for longer bolts, found some, you guessed it, #10, but 24 tpi! Grr, again! Threaded to 24 tpi, bolts are just a tad loose, so I locktighted them in! Anyway Mr Murphy sure was in my shirt-pocket today, as all of this crap made a 1 hour job into 4! Glad that this particular piece aint a high speed, powered something critical! If the worst happens, I can at least go buy some #12 bolts, and re-thread!:)
Oh, and the lathe worked flawlessly!:p
The idler pulley, in question:
https://www.tractorsupply.com/tsc/p...idler-pulley-3-8-in-bore-2-in-od?cm_vc=-10005
nowing75
coatesville indiana
I started buying machine tools about 25 years ago. You can buy the bigger stuff that's 3 phase cheep, its the tooling that will kill you. I have a bridgeport,9" southbend and a 20" swing Lodge and shiply that can take a hell of a cut.
