Manu
The driven gears in an engine do not typically have a very heavy torque load but when they are driving an accessory that exceeds 75 horsepower then it can be problematic.
I’ll be honest and say that for big iron (yellow or otherwise) I personally detest EP oils with a passion. Cat generally stay away from EP so it’s not normally an issue, but I’ve seen plenty of cases on machinery from other OEMs where EP oils have been replaced very successfully with either SAE50 TO-4 or SAE60 FD-1 oil depending on the machine and the ambient temperature range. Currently we run the swing drives, pump drives, rotary heads, and finals of a fleet of Hitachi 3600’s and Atlas Copco DML drills on 60-weight FD-1. The OEM Manual recommended EP90 oil in every case. The improvement in the oil condition as shown by analysis is like night & day.
Interesting information..I didn't recall that service letter..but don't recall the sprocket seals being silicone...although methinks the input pinion from the steering clutches is. That explains why they fail and overfill the final drives with transmission oil..which could cause a failure of the sprocket seal. Although typically sprocket seal failure occurred from dirt forcing itself into the ramp of the toric ring and eroding it and the duocone rings..plus wire etc. that gets wrapped around it when a machine is used in a garbage dump. It is a good illustration of the benefits of a high drive.
In the case of Hitachi we were told "You can't use TO-4/FD-1 oil to replace EP90, we haven't tested it".Shame on you. Hitachi and AC did extensive planning on the breakdown of those machines. Someone else is going to have to pay more for their parts now that you've violated the Prime Directive.
Which is one of the reasons that old-school tractor drivers were discouraged from tracking long distances in reverse, even though the ground speed of the tractor was slightly higher in 3rd reverse than it was in forward. It was almost a sacking offence in some big earthmoving companies.The oil pumps only work going forward, just thought I would say. tctractors
And on the sprocket and bushings by the way they release from the sprocket in reverse. Wear is greatly increased.Plus back blading is hard on the frog and hardware that hold the cutting edges on.
