Hi All,
A couple of updates. I got my service manual in the mail last week and have been reading about how the system is supposed to work. I got through the seven systems, but can't say I really understand it all yet. Need to read through it again.
From the service manual I followed the procedure to adjust the steering linkage. That eliminated the play or free travel in the pedals, so it feels better to drive now. Unfortunately I dropped a 9/16" wrench down in the belly pan in the process. I'll need to drop the back access plate at some point to see if I can find it.
I did drive the machine some more last week and tried to pay more attention to exactly how it was behaving. A few things to note.
1. The steering always starts strong, then fades. Not really so much with being warm or cold fluid, but the start of each turn is stong, then it fades. So when I push a steer pedal, it turns strongly at first, then slows way down as I keep the pedal depressed. It feels like there is not enough flow rate to sustain the higher rate when turning.
2. Lifting the loader arms when heavily loaded slows the engine RPM significantly. The engine doesn't stall, so something seems to be bypassing eventually, but the engine really slows down. I didn't have the RPM app running so didn't get a reading of it, but i sounded slow enough I was worried the engine would stall. All the other hydraulic functons don't do that (tracking straight, or curling bucket). I am digging into an old railroad grade, and know that the arm lift is the weakest, so it may just be too much for the machine.
So, the question for those with more experience than I: it seems like I have insufficient flow to support turning, it seems like this is a flow problem or leak problem in the system. Is the best thing to do next a hydraulic pressure test? I did order a new filter, but the one I received wasn't a Cat brand and when I looked up the part number it didn't cross to any of the Cat numbers, though I'm a bit uncertain what the correct filter number is. The Cat site when I used it had several options, and they changed when I looked it up a second time?!?
Thanks,
Reuben
