New to CTL... looking for t180 info
673moto
NorCal
Slacker
looking for the correct service manual for a bobcat t180. Year is 2004.
There’s a few different books online and not sure which is right.
Also any things I should check with 1800hrs?
Figured on all new filters and fluids. .. but is there anything else I could be doing to start off?
I have a mini excavator but this is my first CTL. Hoping to make it last a while with the right maintenance!
Mark13
IL
You have to take tracks off to change final drive oil?
I think you have to pull off the tracks, drive sprockets, and some little metal shield/guard to get to the tiny amount of oil in each final drive. I think they hold something like 1/3 of a quart.
673moto
NorCal
Slacker
2ounces!
Mark13
IL
Ridiculous! My Takeuchi holds 1.05 quart or so. 3 Plugs on the outside of the final drive, drain, fill,and oil level. They couldn't have made it easier and I don't think Bobcat could have made it any harder on the old machines.
CMC76
Wisconsin
My new holland also serviceable from the outside ports.
I would double check that info. Seems like way to much work for a routine service item
Mark13
IL
It seems ridiculous but I'm pretty sure there's no way to access the oil except through all that work.
673moto
NorCal
Slacker
Yep, found a YouTube video where they guy left the tracks on ... will definitely give that a shot first.
CMC76
Wisconsin
On the outside of the drive. There will be at least one port the screws in. Position it at 6 o clock. Remove slowly there will be some pressure. Allow to drain.
Slowly creep the machine forward until port is at 12 o clock ( a helper is useful )
Then fill to spec. Should be that simple.
Some machines have multiple ports which makes it easier. But the pictures I found of yours used just one.
tool_king
new jersey
road mechanic owner
What is your serial number ? I can email you the manuals.
KSSS
Idaho
excavation
I had no idea it took that much work to dump the drive fluid on a BC. That is a horrible design. I sure that contributes to some failed drives, due to lack of maintenance.
