New svl75 rear idler leaking oil?
Discussion in 'Compact Track/Multi Terrain Loaders' started by zeroo, Apr 6, 2021.
  1. zeroo
    zeroo Charter Member
    Nov 21, 2003
    48
    plumbing contractor
    lexington/tollesboro
    Noticed this today. It is coming from the rear idler. It smells like motor oil. Not grease and definitely not rear end fluid. What the crap. Easy fix but a pain in the *** trip to the dealer.
  2. zeroo
    Nov 21, 2003
    48
    plumbing contractor
    Dumb question, are they oil filled? Do they need maintenance, not that mine should need it at 40hr, but I guess it’s not just sealed bearing.
  3. lantraxco
    lantraxco Senior Member
    Jan 1, 2009
    7,694
    Elsewhen
    Typically oil filled, no maintenance, throwaway. Possible being that new it was just overfilled and the heat will push excess oil out if there isn't enough air space to absorb the expansion. Maybe, lol
  4. zeroo
    Nov 21, 2003
    48
    plumbing contractor
    Makes sense. It was the hottest I worked it since I got it.
  5. Tags
    Tags Senior Member
    Feb 19, 2012
    1,198
    Connecticut
    I would keep an eye on it, if it keeps leaking go right back to the dealer and get yourself a new one under warranty
  6. Midnightmoon
    Midnightmoon Senior Member
    Nov 9, 2013
    290
    Ny
    If it's out of waranty you can rebuild those if the bearing isn't shot. They also can be refilled with oil. If oil came out the bearing wont last long
  7. zeroo
    Nov 21, 2003
    48
    plumbing contractor
    Update. Dealer pre ordered part and I’m here getting it changed. I tried to get them to let me bring the bad roller and exchange it.
    Tags likes this.
  8. zeroo
    Nov 21, 2003
    48
    plumbing contractor
    Roller got changed, they had me out in a couple hours.
  9. Cpaine
    Cpaine Active Member
    May 29, 2017
    26
    Michigan
    I have one on a CAT that leaks once in a while, do you have any info on how to re-seal them?
  10. lantraxco
    Jan 1, 2009
    7,694
    Elsewhen
    They're all similar but a little different, usually the way to pull the seal collars off is obvious, will be a pin or snap ring, etc. Your CAT stealer should be able to order the seals, since nobody stocks ANYTHING anymore... You do one side, flip it, fill it half full with lube while it's open, reassemble and install.
