kshansen
- Joined
- Mar 11, 2012
- Messages
- 11,160
- Location
- Central New York, USA
- Occupation
- Retired Mechanic in Stone Quarry
And you have that guard dog to make sure no one tries to steal it!
About the closest thing we had at the quarry were a couple different "carry decks".
First one was a Drott that looked like this one:
Then that one was moved to another quarry in the state when they were doing some major updating of their plant and we then got one of these:
One thing I liked about the Drott was it had one of the Case 188 Diesel engines just like many of the 1845 skid-steers we had at the time.
The Broderson had a Ford gas engine that was a dual fuel set-up but the propane side was not usable due to problems before we got the machine. I slowly removed 90% of the propane parts and it did run okay but not as good as the Case 188!
The swingout jib was handy at times on the Broderson. But neither were too good in the rougher parts of the quarry.
I liked having the Broderson and the other carry-deck around the shop. As I was most of the time working alone I could often position the little crane and reach the controls from outside to make fine adjustments to the position of the item I was lifting. Also they took up little floor space in the shop.The papermills and taconite processing plants use a lot of these Brodersons. They work very well inside the plants on the flat concrete floors and have a lot of lift for there size. About all you see is propane powered ones. I can see where they could be a handful in rougher terrain.
They are handy.I liked having the Broderson and the other carry-deck around the shop. As I was most of the time working alone I could often position the little crane and reach the controls from outside to make fine adjustments to the position of the item I was lifting. Also they took up little floor space in the shop.
