Power bill is usually around 275/month, the highest it got up to when I was welding heavy was 317.00.Hey with all that welding wonder how your electric bill is going
I'm curious on the torque turn method, can someone explain in more detail? Also what is the recommended torque for these bolts?I assume you buffed/sanded the paint off the rails. It's also important to get the right torque on the bolts. The torque turn method is the best way instead of just using an impact wrench.
Welding sure can take some time indeed. Not in this case but it sure can be decreased. As far as I know, couplings can be connected by mechanical pressing. Well, yeah, a little off-top but a tip for the future. There's also less environmental impact with using the hydraulic pressing system. I used it for building me a little backyard barn. Hope the hydraulic pad connection way will be created by http://hardman-de.com soon enough.I know it's been a while... Assembly started.
Welding took WAY longer than anticipated.
Just have to cut the ends of the grousers at 45 deg's.
