I'm new to this forum and to this machine. All functions work well but the dipperstick has very little power. Meaning it will move with no load and the engine pulls down slightly when it does. But but when I have even a half a bucket it will not crowd, even in loose soil. I have checked pressure at the cylinder and it is 2550 lbs. The engine rpm does not pull down at all. It is as though all the pressure is somehow bypassing actually pushing the load. How is this possible? There are no leaks in the cylinder.
As an aside, when I try to use the crowd function, the curl function power also is greatly reduced. Meaning anytime I am curling the buckat and try to crowd, the bucket curl stops until I let go of the crowd.
Machine has 5300 hours. I had dealer come out, they checked pressure at pump, control valves and cylinder. We changed the filter, it was clean. It is driving me crazy as this is a nice machine, but I cant do squat with it.
