NEW HOLLAND L454 WATER PUMP
Discussion in 'Skid Steers' started by coastbuster, Aug 21, 2020.
  1. coastbuster
    coastbuster Well-Known Member
    Aug 8, 2015
    84
    was a union heavy construction electrician now ret
    Shirley,ny
    Hi Guys,
    I have a New Holland 1991 L454 skid steer that blew the water pump. I went to Malvese equipment here on Long Island and was told that New Holland does not make or supply this pump any longer. So,here I am with a $7000.00 machine that's useless. I took it to my local machine shop and they pressed out the seal and bearings. The roller bearings had disintegrated. I am in the process of searching bearing manufacturers for a replacement shaft and bearings which are all one unit. They call it a "WATER PUMP BEARING". Anybody have any idea where to get the whole water pump? if the bearing replacement doesn't work out. I searched the internet for hours with no results. What I need is a skid steer junkyard. Thanks Dan
  2. 3X8
    3X8 Well-Known Member
    Jul 25, 2013
    107
    United States
  3. coastbuster
    Aug 8, 2015
    84
    Shirley,ny
    Thanks for the post but I already did that search with no results. i will post a pic of the gasket. The pump itself is currently with the machine shop. I'm going there today so I will take a pic of it and post. Thanks 20200821_094910.jpg
  4. melben
    melben Senior Member
    Jan 15, 2008
    828
    pennsylvania
    Could you post the engine manufacturer and model number, It probably can be located that way.
    56wrench, Delmer and Vetech63 like this.
  5. Delmer
    Delmer Senior Member
    Jan 4, 2013
    6,385
    Even the numbers off the old pump itself could be enough to find you a new one.
    It's not likely that there was a special engine made only for this skidsteer, or a special water pump made only for that year and model.
    56wrench and Vetech63 like this.
  6. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    2,759
    Oklahoma
    Have you taken the New Holland part number and thrown it on Google?
    mg2361 likes this.
  7. MarshallPowerGen
    MarshallPowerGen Well-Known Member
    Nov 27, 2017
    204
    Diesel & Generator Mechanic
    Coeur d'Alene, Idaho
    Get a hold of these folks. They've rebuilt some discontinued Ford industrial pumps for us in the past.
    http://www.az-rpm.com/
  8. coastbuster
    Aug 8, 2015
    84
    Shirley,ny
    Thanks Guys. It's an L454 Skid Steer with a Ford engine. Here are pics of the water pump with numbers on it also. Plus the pump says Ford on it too.
  9. coastbuster
    Aug 8, 2015
    84
    Shirley,ny
    it's obviously taken apart.
  10. coastbuster
    Aug 8, 2015
    84
    Shirley,ny
    I wonder if this is the pump. It's made for a floor scrubber and polisher. Compare the pics,it looks like a perfect match. This is the ad but doesn't give any size specs.https://www.ebay.com/p/1135061722
  11. coastbuster
    Aug 8, 2015
    84
    Shirley,ny
  12. coastbuster
    Aug 8, 2015
    84
    Shirley,ny
    Even has the triangular fan attachment point that mine has. The pics I posted don't show that because it's taken apart.
  13. Vetech63
    Aug 10, 2016
    2,759
    Oklahoma
    That number in the pic could be just the manufacturers casting number and not the actual part number.
    mg2361 likes this.
  14. coastbuster
    Aug 8, 2015
    84
    Shirley,ny
    Yea, it doesn't come up in any searches
  15. alrman
    alrman Senior Member
    Jun 20, 2009
    2,805
    QLD Australia
    @coastbuster
    We really may be able to assist you if you posted the engine make & model numbers ...... especially if you post a pic of the tag ;)
    The picture you have posted of the housing doesn't look like any of the three different pumps listed for the three different engines listed in the online parts manual.
    Maybe someone has swapped out the engine to something different to the OEM??
    UPDATE EDIT - just spent a few minutes on DR Google
    It would seem you have a FORD engine model VSG 411/413
    EBAY pump - https://www.ebay.com/itm/ford-indus...r-pump-3-92bx8591aa-With-Gasket-/283496671021
    Hope this saves some old yellow iron from the scrap heap.....;)
  16. coastbuster
    Aug 8, 2015
    84
    Shirley,ny
    You are a genius,that's the pump. thanks a million
  17. coastbuster
    Aug 8, 2015
    84
    Shirley,ny
    You my friend are a genius. Thank You very much. thats the pump.
  18. coastbuster
    Aug 8, 2015
    84
    Shirley,ny
    I have another problem. The cooling fan is shot and I'm having trouble locating another .Here's a pic It's a 15 inch fan from blade tip to blade tip. There are two mounting holes(the larger ones) and they are 2" apart center to center. The hole in the middle is 1.1". It's a 6 blade fan. It has the numbers 390-2-5 stamped on it but I get no results with them. The fan was on the machine and I had no overheating problems but as long as I have it apart I should probably replace that too. Dan
  19. coastbuster
    Aug 8, 2015
    84
    Shirley,ny
    P.S the center hub is 5" across
  20. coastbuster
    Aug 8, 2015
    84
    Shirley,ny
