New Holland C232 oil smell and code 3028
Discussion in 'Compact Track/Multi Terrain Loaders' started by UpNorth Mini Excavating, Aug 20, 2021.
  1. UpNorth Mini Excavating
    UpNorth Mini Excavating Well-Known Member
    Feb 10, 2018
    80
    Maine
    Hey everyone, just purchased a C232 New Holland and it had a bad crankshaft seal and oil was running right out of it. Changed out the seal and now it’s not leaking anymore. Ran it for 6 more hours and I have a oil smell and can’t pinpoint where. The oil is going down on the dipstick. No smoke coming out the exhaust. I also have an engine code 3028 which is low oil pressure by the engine has plenty of oil. Just looking to see if anyone went through something like this. Thanks
  2. GaryHoff
    GaryHoff Senior Member
    Feb 25, 2009
    808
    Heavey Equipment Mechanic
    Alberta, Canada
    I'm assuming there is no external leaks anymore.
    Check your turbo, it may be failing.
    If turbo is ok, check your crank case vent. Should route into the air intake, depending on your year/emission level. Might have excessive blow by, and is sending oil to the intake.
    What year/emissions are on this machine?
    512high likes this.
  3. UpNorth Mini Excavating
    Feb 10, 2018
    80
    Maine
    No more external leaks. What is a good way to check the turbo? See is there is oil after removing the boot? It is a 2011 with no emissions to speak of. Thanks
  4. GaryHoff
    Feb 25, 2009
    808
    Alberta, Canada
    Can you check if your crank case vent is externally vented first?
    Some engine oil at the turbo is normal if the crank case vent routes back to the air intake.
    For the turbo, just take off the charge air hose and look. May be oil there. Take off the intake hose and spin the impeller, and use light down pressure, you may feel a rough spot in the turbo.
    May also be engine oil on the exhaust side of the turbo.
