Y'all be careful out there when your working with these new gas cans...
Was fueling up my chainsaw on the tailgate and just flipped the jug over and tried to fill the saw. The tank had pressurized due to being almost empty and being in the truck bed on a sunny day. I barely cracked the valve and was immediately hit in the face by gasoline. Thankfully I'm a non smoker and wear glasses, so I didn't get it too bad, but I did get some in my eye and all over my face and chest.
What happened to the old steel cans with the rubber hose and plug... That's the can style that almost got me!
You should not be
OSHA Standard 29 CFR 1926.152(a)(1) states "Only approved containers and portable tanks shall be used for storage and handling of flammable and combustible liquids. Approved safety cans or Department of Transportation approved containers shall be used for the handling and use of flammable liquids in quantities of 5 gallons or less.
Anytime the word "shall" is used in a regulation, it means that this rule is mandatory and must be followed.
What is an approved safety can or DOT gas can?
A safety can is (29CFR1926.155(1) an approved, closed container, of not more than 5 gallons capacity, having a flash arresting screen, spring closing lid and spout cover and so designed that it will safely relieve internal pressure when subjected to fire exposure.
Approval is given by a nationally recognized testing laboratory, for example, Underwriters' Laboratory, Inc.
Gas cans can only display DOT approval markings when they meet stringent Department of Transportation requirements. Here is where it gets confusing, inexpensive plastic gas cans may meet EPA (Environmental Protection Agency) requirements, but they do NOT meet DOT rules. Some gas cans may say they meet CARB spill-proof regulations in certain states or AQMD (Air Quality Management
District) rules. Again, this doesn't help when trying to comply with OSHA. None of these other regulatory agencies are the same as DOT. They are not interchangeable.
If your head isn't already spinning, one last point. If you are looking for a UL "approval", you will see the following words on the product, UL Listed. If your can has a UL Classified marking, this is not the same as UL Listed (approved). If you want more information about UL markings, go to
http://************/pxb9dt
Now that you know the correct can to use, shown below are safety rules to follow when using gas cans. This information can be used for this week's tailgate safety
