new dozer tracks
Discussion in 'Dozers' started by Mike L, Sep 26, 2014.
  1. Mike L
    Mike L Senior Member
    Dec 1, 2010
    804
    Self employed field mechanic
    maine
    We need to replace chains and pads on our komatsu d65. Anybody have any after market recomendations?
  2. cyclone77
    cyclone77 Member
    Feb 14, 2012
    20
    Owner operator of kansas oilfield Dozer service
    Kansas
    Might want to check with your local cat dealer, pretty sure they manufacture for all types of machines. In my opinion they are the only way to go as far as quality and hours that you will get out of them. I bought a machine (d6rxl) that Had an aftermarket undercarriage put on prior to us purchasing the machine, only got 1300hrs out of the undercarriage before it went into catastrophic failure. I would be very Leary of anything aftermarket
  3. Deeretracks
    Deeretracks Senior Member
    Feb 18, 2014
    568
    Shop Foreman
    Western Washington
    There are some quality aftermarket brands, you just need to be careful of some of the junk coming out of China and Korea. I use a lot of Berco and haven't had any issues. Stay away from V-Track unless it's a farm machine you rarely use.
  4. cyclone77
    cyclone77 Member
    Feb 14, 2012
    20
    Kansas
    Deeretracks. How many hours are you getting out of the berco's? My machine came with a IRT undercarriage supposedly "brand new" from a used dealer and we only got about 1300hrs before idler bearings went out and slightly before that pins started to seize up. First indication of crappy undercarriage was that Master links were welded together because metal was so soft that bolts kept pulling out.
  5. trackdoc
    trackdoc Well-Known Member
    Aug 8, 2011
    99
    Currently working as a HD Mechanic Trainer in Kyr
    Ireland/Kyrgyzstan
    I would expect 4500 ish hours out of Berco
  6. cyclone77
    cyclone77 Member
    Feb 14, 2012
    20
    Kansas
    We are getting anywhere from 5k to 7500hrs out of a Cat Hd undercarriage in a somewhat coninuously changing environment, rock, sand, clay, and a lot of mud/water truck pulls
  7. Deeretracks
    Feb 18, 2014
    568
    Shop Foreman
    Western Washington
    4500hrs is about it for us using Berco or Deere OEM. All our machines are JD hydrostats so they eat u/c faster than the older machines.
  8. bob455
    bob455 Member
    Oct 3, 2013
    19
    PA
    I would get the komatsu seal and lubed tracks pricey but worth it!
  9. JDOFMEMI
    JDOFMEMI Senior Member
    Jan 4, 2007
    3,074
    SoCal
    How many hours did the OEM tracks go?
    If the life was good with them, think carefully before changing what works for what might.
  10. lbrecht
    lbrecht Member
    Aug 19, 2012
    6
    south carolina
    let your Cat dealer product support rep quote it, let them know what you expect to do with it and environment you plan to use it in. big expense but you will get back what you spend. had a d6n lgp go through a set of v track rails in less than a 1000 hours. Berco not bad but wont last like cat.
  11. Mike L
    Dec 1, 2010
    804
    maine
    jdofmemi, we got 7100 hrs out of the oem tracks. we ended up buying itr chains from tracks and teeth. under $9000 for tracks and pads with a 2 year warranty. hopefully they hold up alright. they showed up yesterday and I tried to put them on today but we recieved 39 link chains and we need 45 link.
  12. Dickjr.
    Dickjr. Senior Member
    Mar 25, 2011
    1,484
    Kentucky
    I bought a dozer that needed rails and sprockets , the seller opted to put a set on for me, they used ITR. So far so good with 400 hrs on them since May. It is on a smaller tractor , D39EX. I did question this , and called other suppliers about ITR. There is 3 different grades , and I have the better of the three.
