New Build Tree Spade For The Skid Steer
Danny Steel
NW Ontario
Farmer/Landscaper/Welder/Fitter
splitter valve maybe?
Yes I think a splitter valve would work, If I went that route
you could always pull stabilizers on the rear you manually set. use some tubing that sides inside each other and cut holes for pins to go in. you can't up pressure on them to lift the rear but it maybe enough to keep the nose on the ground. just an idea that may help you.
I think You guys just like to keep me welding away:);)
I have been working on this today, And went with your Idea, and the others that also pointed It out, with the tube...I figured by the time I got more weight on the front, I could have this rear Stabilizer set up and running
Danny Steel
NW Ontario
Pictures Of The Rear Stabilizers
Ready for paint:notworthy
Danny Steel
NW Ontario
Time to put some load on to see If the welding passes:eek::cool2
We had some bad weather here today, So this worked out good for me
Hope It works,:beatsme I will hook the spade up tommorow
Thanks for your comments, and suggestions
Danny Steel
NW Ontario
The Stableizers are helping, But I still had to add weights to the front
alevins
Interior, BC
tree spade
Hi Danny,
your spade looks great, was wondering how you are making out with it and if you had any sketch's of the dimensions you would share? I could use one of these and building one seems like the best option for me
thanks for any help
Luke
RTSmith
Middle Tenn.
Amateur demolition & dirt pusher
And if nothing else- you have the 4 tire rotate under control in NASCAR fashion! Seriously- great job. Keep us in the loop.
