Neil DD5500 paver
Discussion in 'Pavers' started by Vetech63, Jul 23, 2019.
  1. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    1,920
    Oklahoma
    Just when I thought there wasn't a worse serviceable machine than a Weiler, along comes this Neil paver. Neil DD5500-1.jpg Neil DD5500-1.jpg Neil DD5500-2.jpg
    Yeah, that's the left side hydraulic motor lying on the ground (and I DIDNT unbolt it and lay it there!) 1 bolt was still in the mounting flange but the rest of them are part of the pavement now. The drive planetary had grenaded a gear and wiped out the entire planetary.
    Looks easy to remove huh...……...don't let that fool you. This thing has the undercarriage of a dam tank and there is no EASY way to get this out. I managed to remove the planetary drive by removing the mounting bolts between the mounting plate and the track pads (otherwise, it required dropping the entire track frame assembly.) I will add pics of the explosion later tonight.
    This does lead to a parts issue I am seeing a lot more of...…...which I am starting in the General Forum.
    mg2361 likes this.
  2. Bls repair
    Bls repair Senior Member
    Jan 21, 2017
    1,009
    Equipment operator,mechanic
    S E Pa
    Don’t you wish you could get the engineer that designed this and stuff his butt under there and see how it is in the real world.:mad:
    Vetech63 likes this.
  3. Vetech63
    Aug 10, 2016
    1,920
    Oklahoma
    Should have this build to order drive planetary in 2-3 weeks. o_O
