Needing case mechanic
Msalyers
Ohio
I’m located in southeastern Ohio gallia county I’m looking for someone to look at my 650k series 2 dozer it won’t forwards or backwards and I’m kinda lost
Msalyers
Ohio
I have a 2005 650k series 2 transmission light and parking brake lights are on and it won’t move I checked the x5 connector and no power on pin 28 12 volts on pin 1
mowingman
North Central Texas
Retired
Southeastern Equipment is the case dealer in southeast Ohio. Not sure where all their locations are. Also they have locations in West Virginia.
Msalyers
Ohio
I also have no power at the x5 connector pin 28 key on I read somewhere on here you’re supposed to have power there I have in pin 1 but not 28 I just don’t know what that means
Coy Lancaster
Arkansas
service tech
4532 is directional control forward/reverse axis faulted. Check the connector for the FNR joystick first off. Do you have a service manual?
Coy Lancaster
Arkansas
service tech
There is a section in service manual that identifies each connector you probably will want to look at that. It’s easier for me to get to connector for joystick by pulling it out of console. Of course that depends on you model of 850K. Some have longer harness than others.
Msalyers
Ohio
Update so I replaced some fuses and now I have 3 codes 4531,4531,4621 I can’t seem to find anything else wrong I’ve been using the manual I bought and doing some testing but haven’t had any luck
