hammer time
It isn't hard or very expensive to get set up to recharge yourself , and production will increase if you keep it to specs , what type of charge valve fitting is the hammer using ,all but a few hammers are basic fittings , the allied , atlas copco and kents use something that is unquie , but getable , all you need is a bottle fitting , tee, gauge , some fittings and a hose ------- I saved some money on buying nitrogen bottles , I have three , one medium size for the shop , and two of the small size for the truck , all three were oxygen cylinders that were easy and free to come by , that I took years ago to the local gas supply and they changed the valves on the tanks for $15 each , they can change from oxygen to nitrogen or even argon for the welder but once changed they can't go back to oxygen from what they tell me , ---------the small tanks will charge about 7-10 hammers depending on size and cost $10 to fill , what I have been doing is to link the little tank to a medium tank with a gauge , two hoses and fittings , I can equalize the big tank to the little tank , it don't totally filled it , but enough to do a few hammers with having to go back to the gas supply house -------------650 to rebuild sounds kinda low hours , seems it should last longer than that -------
