PhilDirt
I bought a ArcAir K2000 torch and some carbon electrodes. Connected the torch to my Lincoln Squarewave 175 to try burning off some ugly stick welds. Used 5/32 rods, set it to DC-, 150 amps. I can't get it to maintain an arc. Tried DC+, AC, raised the amperage, etc, still no luck. I can get a decent arc without any air flowing, but not with the air on. I even tried turning on the TIG spark, it will spark just fine but no arc. I can get the rod hot enough to melt, still no steady arc.
I also tried using an old gray TIG 300/300, results were even worse. I also have a red TIG 250/250, but didn't try it. What am I doing wrong, there's obviously something I don't know. I did some googleing and all I found was a reference on a machine rental site that said 3phase welders were needed for air arc work, because they had higher open circuit voltage. Is that the answer? All my machines are single phase.
