Need help with a Smith 100cfm Ford302V8 Tow Behind Compressor ?
Discussion in 'Other Construction/Demolition Equipment' started by Geardoc, Nov 21, 2019.
  1. Geardoc
    Geardoc Active Member
    Mar 22, 2013
    25
    Murphy NC 28906
    Mine had an attempted theft in which the thief, deciding it was too much work to steal my compressor, decided to cut the wires on the coil, steal the coil, air cleaner, and carb.
    He got bit by a Great Pyrenees and abandoned the operation.
    Here is the info I need:
    On a Smith 100CFM Ford 302 V8 with electronic ignition there were two wires that went to each side of the coil,
    Gallery:
    The colors of the wires are: brown, green, red, and black
    Distributor is 84-87 302 style, it is an electronic ignition on the vehicle. He cut the wires on the coil, we have not been able to find the coil, the people who own SMITH have nothing to say to me, manual is no longer available on web.
    I remember distinctly that two wires were joined at a female spade terminal on each side and slipped over the male terminal on each side. But I have no way of knowing which way this goes.
    Does anyone have a Smith Tow Behind Compressor to look at ? I've tried asking on SmokStak but I think it is a bit too new.
    [​IMG]
    [​IMG]
  2. Jonas302
    Jonas302 Senior Member
    Jan 4, 2015
    576
    mn
    Coil will be standard off a pickup from auto parts store I will look at my compressor in the morning see with the colors match
  3. Geardoc
    Mar 22, 2013
    25
    Murphy NC 28906
    Thank you very much
  4. Geardoc
    Mar 22, 2013
    25
    Murphy NC 28906
    Thanks, I got a coil, it's like you said, matches the old one. If you get a chance to look, I'd be extremely grateful.
  5. Jonas302
    Jan 4, 2015
    576
    mn
    I have a green to negative and red to positive yellow taped off
    I dont see the brown like yours 1/4 qc terminals to the coil and see if it will start
    My wiring is pretty hacked by previous "mechanic"
  6. Jonas302
    Jan 4, 2015
    576
    mn
  7. Jonas302
    Jan 4, 2015
    576
    mn
    These are pretty cool compressors they run a ford 302 on 4 cylinders using standard distributor with the extra four wires grounded out the non firing side has a special head in it never been inside so not sure if there are any differences in valve train ect with the 120 gal tank it runs the heck out of a 1 inch gun
    check likes this.
  8. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    4,106
    On A Riverbank in IL. USA
    For what its worth I found the manual for your air compressors. But, it cannot be downloaded even tho it has a download page. All you will get is .pdf file of blank pages.
    My workaround that is to take a screenshot of each and every page if you want the manual bad enough.
    The images below are an example of what I did.
    The link to the page -----> https://www.manualslib.com/manual/1015535/Smith-Air-Compressors-160.html?page=36#manual
    Jonas302 likes this.
  9. Geardoc
    Mar 22, 2013
    25
    Murphy NC 28906
    Thank you. You saved my bacon. Green and Brown to Negative on mine, brown goes to a cutoff solenoid on mine. Red and black to positive. Brown is the oil pressure interrupt. Black is from the solenoid on the head.
    The only Gordon Smith or Smith I ever knew to be bad was the one the successor company(pre-BossAir) got some 477 engines and they stuck them in place of the 460. I had a 477 in a truck and it was bad, but in a compressor it was terrible.
    THANK YOU.
  10. Geardoc
    Mar 22, 2013
    25
    Murphy NC 28906
    The manualslib has a manualslib.com watermark over the coil, making it unseeable. The other thing they did was use the 460 manual for 302, like there was no difference, and unfortunately there is. Besides that manuals lib's scan- if you have a 460 and don't worry about burning something up, you can trace back using the manualslib method you did. THANKS!
  11. Tinkerer
    May 21, 2009
    4,106
    Is this a little better ? :)
    Too bad the publisher didn't print better images.
    mg2361 and Jonas302 like this.
  12. Tinkerer
    May 21, 2009
    4,106
    If anyone wants the watermark free manual, send your email address to me in a PM.
  13. Geardoc
    Mar 22, 2013
    25
    Murphy NC 28906
    I've also used this too in a pinch, it's more work than a screenshot sometimes, sometimes the screenshot is more work.
    https://webpagetopdf.com/
  14. Tinkerer
    May 21, 2009
    4,106
    I have the real manual in .pdf.
    It isn't converted screenshots.
    I only use screenshots for a couple of pages when I want save webpage content.
