watglen
- Joined
- Apr 3, 2009
- Messages
- 1,324
- Location
- Dunnville, Ontario, Canada
- Occupation
- Farmer, drainage and excavating contractor, Farm d
I bought something I shouldn't have.
The plan was I needed a new joe dog to pull my 4 axle float. Farm duty, but we put on some miles.
I wanted spring suspension and Budd wheels. These are hard to find. I found a triaxle dump at the wreckers. Made the deal. He cut the rear axle clip off, pulled out the expensive axle bits and I brought it home.
Started cleaning it up and found the frame has a pretty serious twist in it. I think it got worse when he cut the rails, it wasn't this bad when I inspected it.
So my question is, given two large excavators and a d6, can it be massaged back into anything close to straight, or is no amount of force going to help.
The frame rails are about 1" out of square. That is to say, if you put a carpenters square on any of the cross members, one frame rail is about an inch further ahead than the other.
Using a long straightedge, I can see one axle is off track (offset right) of the other by about an inch.
Lastly, looking at it from the front, the frame ends are rotated one way. From the rear, they are rotated the other way. So the frame is twisted, and the rails are offset.
My questions are: Has anyone ever had any luck trying to beat a frame back into shape? I am worried about tire wear. Is it a concern?
