edgephoto
Guys thanks for all the advice and experience.
I found Cat grease for under $7 per tube to my door. I ordered 10 tubes. I expect the first time I grease the machine for it to take the most grease. If I use 2 tubes every time I grease the machine then I might deal with bulk in a 5 gallon pail.
I have switched all my mix and match battery tools to Milwaukee so I will be buying the 18v grease gun. Again if I really will use 2 tubes every greasing I may switch to the foot operated style that take bulk grease.
I am not a pro and my machine will be lucky to see 8 hours per week.
My machine was an ex-town machine and looks to have had all it's maintenance performed. All the pins have come out easy except one. I found one dry point last week and cleaned out the passages from dirt and dried up grease.
I also have been replacing all the zerk fittings with new ones. This serves two purposes. One is I know that if a joint does not take grease it is not the fitting. Second is it helps me get familiar with the grease points.
