Out of the blue, tons of progress today. As per my last post we discovered the aftermarket side plates had some issues. When I received the plates I noticed the finish on the bearing cups was quite rough. My friend took the plates home and after a lot of measuring and calculating he got the machining done that they needed. We are not sure what steel the cups were made from but they were definitely not hardened and the diameter was different between the 2. The angle of the bearing surface was wrong too, this is one reason we had roughly .125 gap to the diff housing. Luckily I had ordered new cups from Tractor Stuff. He machined the seat depth about .050, not as deep as he first thought of .090. The diameter of 1 plate was too big for a press fit with the new cup so he glued it in with some special glue he has used before on same type repair. Rolling torque, backlash all set. The dual range and shuttle are all spec'd and bolted in place. Now to go thru the axle housings and at least the rear end will be done. Then on to the clutch.
