john146
My mini excavator has recently started shutting down every few minutes; it seems to happen more often if I'm using it - it usually, but not always shuts down when I'm in middle of engaging the ground, but sometimes will also shut down when it's idle. I've checked fuel flow-- the air filter, fuel filter, are new. Fuel pump seems to be working fine; drained water separator.
After it shuts down it won't start right back up; I usually need to wait about 20-30 seconds; then it will run for about 5 seconds and cut out; then starting it about 15 seconds later will let it run well (for a few minutes, and then it shuts off again)
Maybe an overheating issue, but I'm not seeing the temperature sensor light coming on; fan is working perfectly (though the belt could be tighter). I also just topped off coolant. There is ample airflow in the engine compartment though.
