MT55 Kubota not getting diesel
Discussion in 'Mini Skid Steers' started by Parts, Nov 14, 2018.
  1. Parts
    Parts Well-Known Member
    Dec 6, 2016
    73
    DMV Area
    MT55 with Kubota D905 not getting fuel up to the injectors. When you remove the fuel shutdown solenoid and toggle the manual shutdown lever nothing inside moves around. Thinking this is the issue that won't left fuel up to the injectors. Any ideas on what could cause this? Work pulling the pump out the top to diagnose?
  2. Simon C
    Simon C Well-Known Member
    Jul 1, 2015
    52
    North Western Ontario
    Are you possibly air locked and no fuel is moving through the injection pump head. Pressurize the fuel tank 1-2 psi and see if any fuel starts to come out of a loosened injector line. Simon
  3. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    4,453
    Master Inj.Pump rebuilder
    Sunny South Carolina
    If the inj. pump rack isn't moving.. its stuck..pump needs to come out.
  4. Simon C
    Jul 1, 2015
    52
    Yes as Pump Guy says if the rack don't move at all or is seized, it will need repair. Simon
  5. thepumpguysc
    Mar 18, 2010
    4,453
    The HARD PART is.. if its stuck, it needs to move> inorder to get into the correct position to clear the block..
    If u have access to the side of the pump?? I don't know if that mdl. has a throttle access plate? if it does, remove it so u can get to the pump rack & throttle mechanism easily.. & w/ some GENTLE persuation, you can get the rack to move slightly.. enough to get to the engine block cut-out..
    Good luck & let us know if u have problems..
    The parts in there are mostly made out of pot metal or real thin stamped metal{tin} so they wont take a lot of hammering or prying w/o bending or breaking..
  6. DIYDAVE
    DIYDAVE Senior Member
    Feb 18, 2007
    1,270
    MD
    Here is what the pump removal is like, one thing to add, Don't mess up the gasket under pump, that's what determined inj pump timing...
    Note, this is just to show pump removal, your application may have different applications...
  7. thepumpguysc
    Mar 18, 2010
    4,453
    SEE the cut out in the engine block.. {1:28} Your "rack pin" has to be in that position inorder for the pump to come up & out.
    The shims UNDER the pump are very important.. don't lose them.
    "IF" u decide to send the pump out for service.. REMOVE the shims if they're stuck to the bottom of the pump.. they have a strong tendency NOT to came back w/ the repaired pump..{then your screwed}
