Mowing a 3-1 slope with a ctl.
Doug580l
Southern Illinois
I am considering buying a ctl to, among other things mow the back of a dam which is approx a 3 to 1 slope. I would be mowing it sideways and was wondering if that would be safe to do. I have been mowing it with a Kioti dk65 with a bush hog. It is kinda scary as it will occasionally lose traction and slide a little. I was planning on replacing the kioti with another 4wd tractor but am thinking that a ctl might serve me better.
Aside from mowing the back of the dam, there are several miles of trails through the forest that are overgrown on the sides(lots of russian olives) that need attention as well as bush hogging a few times a year. I am also planning on digging a few small ponds.
I talked to a case dealer and he says that the tr270 would handle the side slopes with no problems. I have watched quite a few videos on youtube but never ran a ctl myself. My only experience with skid steers is about 200 hours on a case 1840. It's over 60 miles to the dealer and I haven't asked about testing the machine out here yet, it's too wet now anyways.
I would appreciate some input from guys that have run these machines.
Thanks,
Doug
mowingman
SE Ohio
Retired
Be sure and get a high-flow machine and a high-flow brush cutter. I can tell you from experience that the regular-flow machines will overheat when mowing in heavy/thick grass or brush in the summer. Also, you may get some sideways sliding with the CTL on steep areas. However, you will not turn over or tip if you keep the mower down on the ground. Plus, you can steer the tracks as needed to stay firmly planted on the ground. It should work fine, but I highly suggest you go with the high-flow option.
Doug580l
Southern Illinois
Thanks for the reply, mowingman. I was hoping that the 24 gpm regular flow would be enough. Not many tr270's out there with the highflo. I will likely be buying new so i guess I can order one, don't know how much more that will be than one on the lot. 90% of the trails I mow are not thick at all so that shouldn't be a problem. The back of the dam is about 1000' or so long and varies from about 15' to about 40' wide. Other than the trails, I've been bush hogging early in the mornings while the grass is wet and stop when it dries out so the radiator and ac condenser don't get plugged. I plan on keeping the Kioti(needs a new clutch and probably hyd pump) to do the open areas and use the ctl for the trails and dam. Most of the fields have a lot of areas that I need to back up with the tractor to get. I plan on using the ctl for that too since it hurts my neck to look backwards.
KSSS
Idaho
excavation
I would opt for the tr310 over the 270 for that application. The wider track system on the 310 will hold itself better than the narrower 270 track. These machines make good aux flow, I don't think I would waste the money on high flow for that application. You can get more mower and get high flow but based on what your stating you wouldn't need to have it.
mowingman
SE Ohio
Retired
I realize the high flow option can get pricey. You might not need it if you do not mow in super thick conditions and or very hot weather. My experience has been in both thick conditions and hot weather. If you can afford the high flow, I would certainly go for it. If you are a little more budget limited, then a regular flow machine and mower deck should work ok for you in the conditions you describe. Good luck with your purchase.
Doug580l
Southern Illinois
Thanks for the replies. I am overthinking this, as usual. I was about ready to go for it until I found out that the price I was quoted was a cash price and if I went for the 0% for 60 months Case is offering as I was planning on, it would add about 10% to the price I was quoted. I would normally buy a used machine but with all that I've read about the track systems needing major repairs at around 3000 hours or so, it made more sense to buy new. I worry about buying a used low hour machine like a rental because it's difficult to know if it's been abused. The company I used to work for had several skid steers and a cold planer and breaker, but if they got a bigger job that they were going to use them on for more than a few hours, they would usually rent a machine for it because they are so hard on the machines. Like I said, I'm overthinking, lol
RTSmith
Middle Tenn.
Amateur demolition & dirt pusher
But there's a world of difference between how hard a breaker and a mower are on a machine.
TThe company I used to work for had several skid steers and a cold planer and breaker, but if they got a bigger job that they were going to use them on for more than a few hours, they would usually rent a machine for it because they are so hard on the machines. Like I said, I'm overthinking, lol
RTSmith
Middle Tenn.
And why must you do it sideways? I do most of my mowing with ag tractors, and have always been taught to go up & down steep slopes...???
AllDodge
Kentucky
If you were just going to cut grass I would suggest Kubota F series, but heavy bush hoging and such you have it right
Doug580l
Southern Illinois
The point I was trying to make is that I am worried about buying a rental machine or a used machine not knowing if the machine has been worked very hard or abused. It seems that the dealers don't give much of a price break for a machine with a several hundred hours on it compared to a new one anyways.
Doug580l
Southern Illinois
There isn't enough room at the bottom of the hill to turn around for most of the hill. There is also an area where the pond leaks at the base of the hill that is extremely soft. First time I found it with the tractor one of the front tires sank to the axle. I assume that a ctl with a lower center of gravity and tracks has to be safer to use that the tractor I've been using.
Thanks,
Doug
DIYDAVE
MD
On My ASV RC30, the built in meter on the dash, is right over a sticker that says do not operate at over 15 degrees... I would mow the bottom 5-6 runs, across, then go up forward and back down the hill. They start to feel tippy, at 15 degrees, whether they do, or not. Your grade is prolly at about 18-19 degrees. For the record, I mow a hill with this machine, in the manner stated, and that hill measures 35-38º... When You are approachin that 38º part, your ass starts takin a bite, outta the seat! Also known as the sphinctomanometer angle gauge...;)
Doug580l
Southern Illinois
Lol, Don't think you could get me on a slope any where close to that.
DIYDAVE
MD
This is a hill on the farm, that is too steep, to farm. Starts out at about 15-20º, and gets steeper, as you go up! Hope to keep it mowed, this year with the Altoz TRX. that thing loves steep slopes...:D
JBrady
NE OK
I agree with AllDodge and that is what I have done. Mine is a John Deere F935. It's a front deck mower that was made in the late 90's/early 2000s before zero turns took over. They sell for ridiculously low prices for what you are getting. I bought a F915 for $500 and a near mint condition F935 for $2000. You can't even buy a decent riding mower for that. It has a yanmar diesel in it and will climb hills like a billy goat. 72" cut on the F935 and way more comfortable when mowing. It won't cut a 3" blackjack oak, but it will cut black willows and all the other junk that grows around a pond all day long.
Doug580l
Southern Illinois
I just looked up some info on that TRX. Cool looking machine! I saw an add that said the TRX7661 can cut up to 2" thick material. The prices are lower than I expected too.
Doug580l
Southern Illinois
Interesting. I see that is a 2wd machine? Will it do the 18 degree side hills? We have pretty well decided to wait at least a year before buying a ctl and this could do several of the things I need done. Only downside is that I assume I can't let the back of the dam get so high between cuttings. I only did it once last year because I hate the constant feeling that I'm going to tip over.
