Moving excavator
Sk1970
Nebraska
Have 102” wide lowboy 26’ well. Moving 325 11’ 1” wide haven’t been using any outrigger but it getting cold frozen material on pads. What type wood are people using for planks and how long are the planks you use. Thanks
Junkyard
Claremore, OK
Field Mechanic
Oak for outriggers. Depending on how thick your brackets are set up to use a 16’ might be more than you want to handle lol. Mine are 10’ or so. Measure your outrigger spacing and make sure the length you choose catches one at each end, especially the front so you don’t track over and pop it up. Also, have them cut about 1-1/2” narrower than your brackets so you can still get a hook into the flange of side rail for tie down should you need it.
suladas
Pretty much this, I will take a weedburner to loosen up the frozen crap if needed. If you sit back far enough, you can safely thaw out door locks with a weedburner too.
Depending on location that might work, but here it's not possible in the winter. When it gets down to -30 or colder they are frozen so solid it would take hours upon hours to have any hope of getting the pads clean, and as soon as the machine spends 30 mins at the next job they will be just as full again.
Jonas302
mn
If the hoe is your only load consider making guide rails on the inside of the tracks
Winter gets sketchy whether you clean the pads or not outriggers are a pain and if she gets sliding they may not help last ones we had were 3" white oak around 10 feet long a little taller than the deck to try to keep things on the trailer
Shimmy1
North Dakota
It absolutely is possible. I've had to knock the pads off 4 times in one day before. It pretty much is the worst day of your life if you are alone, luckily I had Dad there that worked one side while I worked the other. 8 lb sledge knocks the pads clean. Yes, they are packed full again in 30 minutes, but if you've ever slid off a trailer and laid one over on the cab, you will make sure they are clean before crawling up the ramps ever again.
"If the hoe is your only load consider making guide rails on the inside of the tracks"
great idea. Maybe build some rails and sockets for them, like stake sides. I remember sliding off a tilt trailer many years ago in winter with a small dozer. Not so much fun. No harm but less drama is always welcome.
I did one job on clay that it took us 3 hours to get most of it out. The job was a Cat dealer, the whole building was on grade beams because of that clay. I had to cover the "Deere" logo on the boom and counterweight to dig the job. They could have provided a Cat for me? :D
