Motor grader road maintenance guide
Discussion in 'Motor Graders' started by Cat 140M AWD, Mar 8, 2020.
  1. Cat 140M AWD
    Cat 140M AWD Well-Known Member
    May 31, 2012
    158
    Motor grader operator
    Montrose S.D
    69E72836-CCAF-4BEB-898D-280D503F531F.jpeg 806EEEE4-3C21-403E-9D00-9FFBABD1D932.jpeg 5B472ABC-6B28-4924-A8BC-221C9676DFE5.jpeg 3CAF96B5-E8A4-496A-8134-BF47A8E44C65.jpeg Here our pictures of the handout I use to teach hands on Motor grader training with the South Dakota LTAP
    hvy 1ton likes this.
  2. Cat 140M AWD
    May 31, 2012
    158
    Montrose S.D
  3. Cat 140M AWD
    May 31, 2012
    158
    Montrose S.D
  4. DBDLS
    DBDLS Well-Known Member
    Mar 11, 2010
    222
    Heavy Equipment Operator
    Campbell River, BC
    This looks like interesting information. Is there a published copy I can get of this? Thanks for posting.
    Cat 140M AWD likes this.
  5. cuttin edge
    cuttin edge Senior Member
    Nov 9, 2014
    1,149
    Finish grader operator
    NB Canada
    Roads here run a 3% crown. Most government paved roads are 2 9inch lifts of 3 inch minus material, 6 inches of inch and a quarter minus, 2 2 inch lifts or base asphalt, and an inch and a half of seal.
    Fatgraderman and Cat 140M AWD like this.
  6. Cat 140M AWD
    May 31, 2012
    158
    Montrose S.D
    Majority of this handout comes from this book if you google it you should come across a pdf of the book if ya don’t find anything I can email you. 41DCC075-769E-4854-A8A8-32AD9BCF50F6.jpeg
  7. Cat 140M AWD
    May 31, 2012
    158
    Montrose S.D
    Thanks for sharing always find it interesting how others do things.
  8. Nige
    Nige Senior Member
    14,974
    Google is your friend. 30 seconds of searching and here's a link to the complete document in Adobe pdf format. All 153 pages of it.
    https://www.fhwa.dot.gov/construction/pubs/ots15002.pdf
  9. ovrszd
    ovrszd Senior Member
    Apr 1, 2008
    961
    Retired Army
    Missouri
    Good stuff!!! Thanks for posting this thread!!!
    Only thing I read that I didn't agree with was using a torch to straighten a worn cutting edge. Was surprised there was no mention of rotating the edges. I would never consider using a torch to remove material. Seems counterproductive. :)
    I've had some heated discussions with farmers about how their gateways should meet my roadbed. They want them shaped like the example of how to NOT do them. So we discuss it for a few minutes and then the inevitable question must be answered. "What is the priority, the road or the gateway?" In the end logic prevails and they understand. I have worked on many field entrances . The runoff has to be directed toward the road ditch before it gets to the road right of way.
    I'm in the middle of a FEMA Disaster Relief claim. Was discussing the tonnage rate for re-establishing a gravel surface on my roads that were eroded away. Your gravel application guide is what FEMA is using to determine my replacement gravel. To make it more understandable and logical, on my 16ft roadbed, 7 feet per ton of gravel. 17 ton load covers 119 feet.
    Thanks for the link Nige!!!
    Cat 140M AWD and Mother Deuce like this.
  10. cuttin edge
    Nov 9, 2014
    1,149
    NB Canada
    we torch them straight all the time. When you're making ready for asphalt, you want a perfectly square edge
    ovrszd likes this.
  11. Nige
    Nige Senior Member
    14,974
    No worries. You're more than welcome.
    I've downloaded it too, You never know when something like that could come in useful, even if it's only as a tool to (metaphorically-speaking) beat someone over the head with........
    ovrszd likes this.
  12. Cat 140M AWD
    May 31, 2012
    158
    Montrose S.D
    Your welcome figured this thread would be useful to a lot of people on this forum I myself don’t cut my edges straight with a torch simply because I don’t use a regular true harden blade anymore I run the double carbide edges and have been getting 4 years on a set that’s grading and plowing snow putting a new set on this spring and keep my old set for snow plowing suer enjoy not having to change edges.
  13. ovrszd
    Apr 1, 2008
    961
    Retired Army
    Missouri
    Yep, I can totally understand that. Just can't understand it in regards to gravel road maintenance.
    cuttin edge likes this.
  14. ovrszd
    Apr 1, 2008
    961
    Retired Army
    Missouri
    Yep, I saved it as well. :)
  15. ovrszd
    Apr 1, 2008
    961
    Retired Army
    Missouri
    Can you post a pic of your cutting edges?? Not sure I understand what you are using.
    I've put 320hrs on our new grader and still on the first set. I've rotated them 5 or 6 times.
  16. Cat 140M AWD
    May 31, 2012
    158
    Montrose S.D
    AED20213-39FF-45E0-A1AD-C050DE5C5CC4.png 7E16D920-BED6-42FD-98B2-F402ED889149.png
    Here are a couple of pictures of the double carbides I run
  17. ovrszd
    Apr 1, 2008
    961
    Retired Army
    Missouri
    I'll bet those things are heavy!!!! Is that why you use 48" length?
    I can see how the thickness would increase wear time dramatically!!!
  18. Nige
    Nige Senior Member
    14,974
    Our graders run 8ft x 12” deep 1-1/4” thick flat edges. Try picking one of those up....:confused::confused:
  19. ovrszd
    Apr 1, 2008
    961
    Retired Army
    Missouri
    Wow, I didn't know you could buy cutting edges that large!!!!
  20. Nige
    Nige Senior Member
    14,974
    IIRC they weigh something like 350 pounds each.
    ovrszd, Cat 140M AWD and DB2 like this.
