Hi folks, here is my quandry:
A fellow that I do business with has been asked to submit a proposal to replace the floor (concrete) of an 80,000sf building. The existing floor is cracked and has settled in places, and is not satisfactory for the intended use. The following are some of the constraints that need to be considered:
1) This building is in a metropolitan area, trucking material in or out would be very difficult, so much so that a permit is required for traffic blockage in order to provide access for concrete trucks and pump truck.
2) The height to the ceiling is 13' from the existing floor.
3) I suspect that excessive noise and dust would not be acceptible.
4) The finished elevation of the new floor can be raised, but thresholds etc. would have to be blended to match.
My first thought is that it may be best to coat the existing floor with latex and pour over it. I am not a concrete contractor, but we are in the process of discussing this option with our concrete contractor. I am unsure of the structural integrity of the existing floor, or whether or not it would be a suitable substrate to pour over. Perhaps an engineers services might be required to ascertain this, or perhaps whatever settling is likely to occur has already done so.
We are considering breaking the concrete and processing within the building to create an aggregate that could be placed, and perhaps mixing with the aggregate that is beneath the existing concrete, in order to re-compact and pour on. I doubt that we could find a small enough concrete crusher to process within the building, and even if we did, the noise and dust issue may prohibit this. The dust could be mitigated with water perhaps, but the noise issue might be insurmountable.
The client specifically asked for a proposal that would not require hauling the existing concrete out.
I am very interested if any of you have experience dealing with this type of problem, and if so, would you be willing to share your insights?
Thank you, I appreciate your input and ideas.
