antinejtrino
The joysticks on this excavator are very loose. They cannot return to neutral.
Glad to hear your communication problem is fixed. But the error codes indicate a bigger problem--JOYSTICKS!. Codes 52,53,54 indicate the voltage output of the joysticks when centered is not within specifications, 52 is for front-back function of left hand stick is below 2.3 volts, 53 is for left-right function of left stick is below 2.3 volts, and 54 is for front-back function of right stick is below 2.3 volts. Diagnosis guide says "If one of any channel is out of center, all channels stop. Wait until joystick comes back to center. Operable only if all channels are set in center." When my left-right function of right stick went out, error codes for both sticks were present- so the issue is identifying which component of which stick is actually malfunctioning. Code 66 is for microswitch of front-back left stick. Diagnosis guide says "If microswitch is on more than 1 second with joystick centered, troubled channel stops. If microswitch is OFF with joystick is ON, troubled channel stops." With errors 52-54 you should be getting a blinking monitor and buzzer; with error 66 you should be getting a constant ON monitor and buzzer. I'll now try to lead you through testing for errors 52-54. Remove seat so you can access the controller while connected. Remove controller cover and look for test points labeled TPG=ground, TP1-TP4= joystick outputs. You will also find TP5-TP8-- those are for the Differential transformers on the valve bank- not relevant yet. TP1 measures output of front-back function of right stick; TP2 for Left-right of right stick; TP3 for front-back of left stick; and TP4 left-right of left stick. With the switch on and the safety lever locked, measure the out puts of each test point. With sticks centered each TP should measure 2.35-2.65 volts. TP1 should measure 0.35-0.65 volts with right stick full front and 4.35-4.65 at full rear. TP2 should measure 0.35-0.65 volts with right stick full left and 4.35-4.65 at full right. TP3 should measure 0.35-0.65 volts with right stick full rear and 4.35-4.65 at full front. TP4 should measure 0.35-0.65 volts with right stick full right and 4.35-4.65 at full left. If measurements happen to be within range, but for reverse positions of stick, it is because the translator of my manual got stick positions wrong, not a bad component. While you are inside the controller, see if the connection leads of plug 182 are numbered. If they are, continuity between leads 8 and 10 test for the left stick front-back microswitch error 66. Centered = no contact; front or back= contact. If not labeled, pull 182 off and facing contact point end with lock mechanism up, lead 8 will be fourth contact from right of bottom row of contacts and contact 10 should be third point from right on top row.
Hello. Yesterday I measured the voltages at TP1-TP4. They were all out of order. Adjusted potentiometers - joystick errors disappeared, boom and bucket started working. Now the mechanics of the joysticks need to be repaired, since due to the strong backlash of the joysticks, they cannot be in the center position. Thanks to everyone who helped with advice in this repair! Without this forum, I would have had a hard time with this excavator.
can anyone help me with my mitsubishi mm30sr ???
the joy sticks wont work or the spin pedal but the blade and tracks do,
i have exhausted my efforts on what i can do. im new to this machine and would like to make it work so i can use it for my yard.
any help would be greatly appreciated.
thanks casey
I have had the same problem. Have either of you fixed your problem yet? I have a copy of the Diagnostic Manual for the Electronic system for Mitsubishi MM30SR , MM40SR , MM55SR , MM55SR-2 These were translated from the original Japanese. Also have parts manual for MM30SR. Does anyone know how I could reach these guys? Thanks td6man
Passed manuals to you as email
Hello Robert,
I sent the manuals to you as email attachments. You should get 4 PDF files. Thanks to reefermike who was kind to send them to me.
All the best from the farmerboy
reefermike was nice enough to send me the manual in PDF from. It is in Japanese and is useful mainly for the exploded diagrams. Part numbers do not work through to anything I can figure out yet. I will pass on but they contain no electrical or diagnostic. I had a problem with the machine not answering the controls and only able to operate blade up/down and tracks power. It all came back to normal when I moved the valve in the boom from thumb control to sideswing and back to thumb with a twrench. Beeping on computer stopped and all is well. Have to adjust it back and forth on occasion as boom becomes sloppy and is half in sideswing. All the best from farmerboy.
I also have a mitsubishi mm30sr . Joysticks are electic operated they do not work . Tracks and blade works . The controler on the right side got water inside . Can it be bypassed or where can I buy one. Someone said they changed them to operate mechanicaly. What can I do?
I found a solution to my problem of a missing processor. A company in Australia - IMDynamics, make an alternative analogue control box which replaces the computer in these machines. I had to send my joysticks to them first (a long way from Ireland) for them to match the control. I had to do a bit of installation of rewiring which was fairly straightforward and I'm very happy with the outcome. You need to ascertain the model of your joysticks to see if they work with 12 volts.
Mine were Kawasaki ERU2-1.
