mini-zerk or WTF?
towbar
Quebec
retired
I've never seen these lubrication fittings before, they were certainly overdue.
A 5/16" eyeball joint, the fittings is barely 1/8" in diameter. In this application what is being lubricated, the threaded bore, the eyeball, or both?
They're called flush-mount grease fittings but I see no mini-gun to fill them.
Camshawn
Langley BC
retired
Those look like oil ports. My lathe has something that looks similar. Just hold the pump oil can up to the fitting and pump. The oil pushes the ball down and it springs back up. Cam
MarcusZ1967
Mrshfld, Missouri
Do-All
Swivel and the end of the thread..
towbar
Quebec
retired
I'm just finishing up and maybe taking a PTO teleflex on shakedown today (pictures tonight if done). It's got two of these on the ends. I don't think I need to lube them since they are new but I'll have to try so as to be up to speed. Will need to buy the adaptor which is always a two-week deal. I bought enough elbows to have spares so I can even do it on an unused one and watch what goes on inside :)
towbar
Quebec
retired
Forgot the pictures
The guy who made the cable made one of the ends with a 6 inch protrusion that I didn't want. The total length was what I asked for although even that was wrong because what I was modeling on wasn't the OEM one.
On the front I took care of 2" with an adapter (blue) while at the handle I dropped the bulkhead fitting 1-1/2" and raised the handle base 2-1/2". It works although there is NO spring holding it in disengaged and no lock holding it in engaged. I don't know, never saw one of these before in my life! I tested static, no problem; the dynamic testing is yet to be done.
