PeterG
You'll figure it out, running an excavator is an excellent lesson in physics.
The load you have changes the conditions. An empty 12" digging bucket is not that much counter balance up above you. A 2' wide bucket is better. A 3-4' bucket is a lot better. You still want to keep the bucket low to the ground and extended out up the hill. A 3' wide bucket full of gravel is a very good counter balance. A thumb full of brush, not very good. A large 2-3 man size rock, or huge log has the weight, but not if you loose it and it rolls down onto you. A weight on the down hill side seems like not a good idea. But as always, you can have the item/load pulled in towards the machine and barely off the ground. If you tip, which is fine, you're only going to tip less than a foot or you can let go of the load. If it's so steep it seems sketchy anyway you look at it, then go down the hill to a flatter area, make the traverse, and go back up, or excavate a traverse, and build a level route, or forget your plan. Be ready for plan B.
If your entire property is on a hill, maybe go ahead and excavate a flat route through. Then you can get in there on a UTV, tractor loader, or 4wd truck.
build those as roads and level them out because they're handy. Let's face it.
The little 5-ft wide bench is not going to hurt you as long as you think about what runoff is going to do.
