Bearhead
I have an IHi 55N3 (5 ton) that has hydraulic controls(not electro hydraulic). Was digging and the boom started lifting by itself. When pushing control to lower, it will eventually slow its lift and then stop, and then one can make it descend. As soon as one applies any lift/raise function, it starts back by itself to raise.
I took the valve body for the boom apart and did not find any debris or glaring issues, but i did service the valve while it was still installed on the bank for obvious reasons. Oil level is good and rest of the hydraulic functions are 100%. If I switch the controls to backhoe mode, it will replicate the same issue, but on hte other joystick, so that eliminates that actual hand controls. Any ideas? machine has 4000hrs and is very dependable(not now
