oldseabee
By your S/N the steering pump is P/N 450022, there is a gear set kit which includes both gears, the body bearings, and the seals, if the housing is OK. P/N 942428.
I can't help you with parts as ours was still complete and working when parked and and I'm not quite ready to start parting it out. The headlights and tail lights were made by Guide I think and were probably used on other things. I think Guide was a division of GM. The gauges were also not Michigan specific but I don't remember who made them. The dash is just a flat sheet and could be made. Same for the side panel below the seat. The engine covers will be the toughest to find as many were discarded or run over when someone forgot to put them back after checking oil. The bar you mention has me confused. Do you mean the bar in front of the radiator or is your front sheet metal missing? At this point pictures would help. The original seat bottom was just a piece of plywood with foam and cover stapled to it that sat on the angle iron above the batteries. The back was the same but attached to brackets. I don't have the original seat but I can post pictures of some of the other stuff if you need it in your search. Ours is a diesel so stuff around the engine might be different.
DO YOU STILL HAVE PARTS THANKSi got parts
hello, i have a transmission, transfer case, axels, tires and rims, ill sell for real cheap
Travis2do you have phone number or e-mail i can contact you thanks
how can i contact you ThanksDO YOU STILL HAVE PARTS THANKS
Travis you still have parts , I.m looking for charge pumpi got parts
