G'day
Went to do a job on a MF50HX S series the other day. The drive shaft for the hydraulic pump stripped, the customer replaced the shaft and the driven gear in the pump. He also changed the oil and fitted new filters. After reassembly the hydraulics are now cavitating. The machine is jumpy and the pump is noisy. After closer inspection I found that the seal was damaged on the suction filter, hence sucking air. I replaced this and the machine worked fine
I got a call 2 days later saying it's playing up again. He has now replaced all flexible hoses on the suction side, tried running it without the filter and fitted the correct seal to the filter housing. Still no luck
Can anyone suggest anything else?
I think my last option now is to pull the pump off and make sure he has put it back together correctly when he had it apart
