The plate says CG825C, max speed 51 OD, serial 67758, series AD9.
Any comment about the dual air gauges?
With a serial number of 67758 it would have been built after October 1955.
Forgot to mention, the guy said it has a iron lung 220 Cummins and straight pipes
Did a quick search and found this:Had never seen a VT430
Is that because the tandem deck-trucks are not as good as they used to be or because the combines may be a little larger!I’m pretty sure you can’t haul a combine on a tandem deck-truck anymore
I have hauled several on a 20 foot goose neck . But there hard to make work after i torch them up.I’m pretty sure you can’t haul a combine on a tandem deck-truck anymore
