Been Body modifying boys a LONG Time!!!
That car, fast back, by the right rear of the truck looks like the old 1950 Buick Special I had on the early 1970's. Bought it of an old lady who I mowed the lawn for, recall I paid $25.00 it had been sitting in her back yard for a couple years. While towing it home behind dad's pick-up decided to put the Dyaflow transmission in gear to see if it would turn over. To my surprise it started to turn over and in a couple seconds was running smooth as can be.1951 Cummins V12 1486 cu.in. Basically two 743's. With the Kenworth three man cab. Look at the trucks
in the back ground.
Yep good old straight 8 really the only reason I got rid of it was the reverse went in the transmission and I did not have the time or place to work on it. It even had hands free starting, just turn on key and push down on the gas peddle, there was a switch on the carb and a relay that engaged the starter. Forgetting what kept it from engaging once it was running, maybe a normally closed relay that worked off the generator output? Or possibly a switch on the transmission to delete the starting circuit when shifted out of neutral. It has been half a century since I saw that car so I'm a bit fuzzy on some details!Straight 8?
Don't recall having a problem with the overheating. One odd thing was the signal light switch was mounted to the right side of the steering column same side as the shifter. The shift order on the shifter went from park, neutral, drive, low to reverse.Not had opportunity to see one of those first hand other than in a museum, spooky. Dad's recollections of the Straight 8s was the rear two cylinders steadily ran Hot and were first to fail in a overheat. Torque Monsters!!
But how handy was the passenger door with that exhaust stack?
They should have ran that exhaust stack
inside the cab and out the top for winter heat.
Always looking out for driver comfort aren't you.
