Memories for us old truckers
Discussion in 'Old Iron!' started by Truck Shop, Feb 27, 2017.
  1. Truck Shop
    Truck Shop Senior Member
    Dec 8, 2015
    7,496
    star gazer
    SE Washington St
    Me-Gas engines like 391, 477, 534 ford-392, 549 blue and red diamond. Diesel engines 220, 250, 335, 350 small cams, All of the big cam engines,
    plus the KTA series, Cat 1673, 1693, all A, B, C 3406 and C15 plus 3408, Detroit most of the two strokes plus Series 60 and DD15. IH DT466.
    Only a sorted bunch of Mack engines. Most all American and Foreign makes.
    Gearboxes Eaton, Spicer and sorry to say Rockwell.
    Rear ends Eaton and Rockwell.
    Worked all those models above at one time or another. Any of the Ford and IH gassers were hard on cylinder wear and pretty much mutts.
    The Detroit's were really nothing to rave about, low on hp and torque, filthy and took up too much room as any V engine does. good in a boat.
    Cummins-they couldn't leave well enough alone, too many changes and Cpl's that made little or no difference in performance. The VT 475 Hp
    855 was a prime example of stupid stuff. Piled twin turbos and went to variable cam timing to try for more hp and lower emissions. Those engines
    would produce 50 lbs boost-the 855 was not designed for that, crank bearings wore and cylinder heads and block couldn't take the stress of the high
    boost.
    Not even going to discuss two strokes-that engine does not like rpm changes, not meant for highway use-ok stationary or boat.
    Cat-only engine they built that didn't belong in a truck was the 3408 too damn big setting in the rails and weighed too much.
    The only way aerodynamics work is the trailer has to sucked right up to back of cab, otherwise a waste of time. Trailer foils are totally worthless.
    59 North, DMiller and bccat like this.
  2. Truck Shop
    Dec 8, 2015
    7,496
    star gazer
    SE Washington St
    Like mine it's just another mack.
    DMiller likes this.
  3. skyking1
    skyking1 Senior Member
    2,308
    Yours is a beauty, That is an offroad beastie and I'm a dirt guy.
    We had one each of the -92s, a ford 292 with that toasty hot crossover and Pee Poor oiling with the added kit for the rocker shafts,
    and a cornbinder 392.
    Truck Shop and DMiller like this.
  4. Truck Shop
    Dec 8, 2015
    7,496
    star gazer
    SE Washington St
    Whipple engine rotator, starter.UK-I can just see that joint coming loose and blood spilling.
    kshansen, 59 North, 56wrench and 3 others like this.
  5. DMiller
    DMiller Senior Member
    Feb 22, 2010
    11,293
    Almost Retired
    the correct quote is walk calmly to the machine of choice, open door, insert hand into door frame opening, slam door three times or draw blood, now ready to drive a Detroit.
    renovator, kshansen and Truck Shop like this.
  6. Truck Shop
    Dec 8, 2015
    7,496
    star gazer
    SE Washington St
    Can you imagine driving this hemorrhoid maker, two story turd. Why bother.
    56wrench, DB2 and DMiller like this.
  7. Truck Shop
    Dec 8, 2015
    7,496
    star gazer
    SE Washington St
    Ain't that the truth-foot to the wood.
    DMiller likes this.
  8. DMiller
    Feb 22, 2010
    11,293
    Almost Retired
    Astros and Titans GMs gift to mechanic job security.
    Truck Shop likes this.
  9. Truck Shop
    Dec 8, 2015
    7,496
    star gazer
    SE Washington St
    I remember the first Astro-George Jettson truck I put dash valves in. GM must have hired someone with a file to sharpen all the metal edges
    in that dash, I had more cuts and nicks on my hands, great ad for band aids.
    DMiller and skyking1 like this.
  10. petepilot
    petepilot Senior Member
    Jul 7, 2018
    1,825
    central shenandoah valley va,
    to damned sorry to sharpen their shear blades
  11. Old Doug
    Old Doug Senior Member
    Oct 16, 2013
    2,274
    Mo
    What about when they left one in gear you know this had to happen.
    DMiller and kshansen like this.
  12. skyking1
    2,308
    I think that's where the broken u-joint is happening in truck stops imagination!
    DMiller and Truck Shop like this.
  13. Truck Shop
    Dec 8, 2015
    7,496
    star gazer
    SE Washington St
  14. Birken Vogt
    Birken Vogt Charter Member
    Nov 30, 2003
    3,672
    Grass Valley, Ca
    So what is a Fuller 15-G-1120 compared to a modern transmission?
  15. DMiller
    Feb 22, 2010
    11,293
    Almost Retired
    Single countershaft marriage box
  16. Truck Shop
    Dec 8, 2015
    7,496
    star gazer
    SE Washington St
  17. JPV
    JPV Senior Member
    Aug 20, 2015
    581
    S.W. Washington
    I remember seeing that Mighty Mite at a truck show in Portland when I was a kid 30 years ago, I remember it was the coolest thing I had ever seen in my life! I wonder where it is now.
  18. skyking1
    2,308
    who did they get to drive that thing?
  19. Truck Shop
    Dec 8, 2015
    7,496
    star gazer
    SE Washington St
  20. 525isx
    525isx Well-Known Member
    Jul 4, 2010
    91
    log trucker
    western wa.
    Kobelco ireland, mks, JPV and 3 others like this.
