Memories for us old truckers
Discussion in 'Old Iron!' started by Truck Shop, Feb 27, 2017.
  1. Truck Shop
    Truck Shop Senior Member
    Dec 8, 2015
    3,951
    fry cook
    SE Washington St
    Well that Frontier truck above says Forks Wa on the door so I would suppose that is a ceder on the bunks.
    DMiller likes this.
  2. crane operator
    crane operator Senior Member
    Mar 27, 2009
    4,225
    sw missouri
    Well its not really a old truck, but its in need of some serious help. Its a (I'm guessing) mid 90's western star. 3406b, 15speed. Meth heads pulled a bunch of the air lines out, thinking they were copper. But left all the battery cables, go figure.
    Anyways, the frame has been cut, I don't know if they were shortening or it was bent and they added a cut off rear or what, but I'm not a big fan of where it was cut at, and it sure doesn't have much of a sleeve area. They had a air lift axle just ahead of the tandems and were pulling a 60 ton RGN with this. Miracles happen every day.
    Of course, its a old sleeper truck, with the famous piece of clouded pexiglass, self tapping screwed and siliconed to the back of the cab.
    I think its headed for the scrapper, he tried to sell it a few years ago for $15,000, and it was rough then, its really in bad shape now. I really don't want it, but I think the motor and trans would be worth something (it supposedly runs), and I wouldn't mind having the aluminum rims. Someone probably wants the hood and grill, but there aren't a lot of western stars around here.
    20200115_082341.jpg 20200115_082651.jpg 20200115_081857.jpg 20200115_082638.jpg
    Truck Shop and DMiller like this.
  3. Truck Shop
    Dec 8, 2015
    3,951
    fry cook
    SE Washington St
    Some nice modifications they did, that's some fine welding. Small hole stud pilot aluminum wheels $90 bucks each, 3406b $5000 complete if it runs, 15 speed used in working condition $2,200,
    depending on the rear drives Eaton 402 3.91 ratio front $1,500 rear $1100, Those air cleaners are worth $250 each , Axle housings $600, hubs $200 each, Steer axle $450.
    A 15spd is getting hard to come by, especially a RTO or RTLO.
    DMiller likes this.
  4. mitch504
    mitch504 Senior Member
    Feb 27, 2010
    4,508
    Andrews SC
    I'll chip in $10 for the lightbar
    DMiller and Truck Shop like this.
  5. Truck Shop
    Dec 8, 2015
    3,951
    fry cook
    SE Washington St
    Yep that old halogen light bar is worth about $10.
    DMiller likes this.
  6. RZucker
    RZucker Senior Member
    Jul 7, 2013
    4,102
    Mechanic/welder
    Wherever I end up
    Oh, h$ll no on that frame splice. I wouldn't do that on a pickup.
  7. DMiller
    DMiller Senior Member
    Feb 22, 2010
    7,386
    Retired
    Was it a splice or a backing plate for lift axle?
    EDIT,
    Never mind saw the weld line they ground down.
    Ronsii and Truck Shop like this.
  8. Truck Shop
    Dec 8, 2015
    3,951
    fry cook
    SE Washington St
    That was some great fabricating, well planned and some of the finest welding technique that was done by a design/structural/welding wizard.
    RZucker and DMiller like this.
  9. dieseldog5.9
    dieseldog5.9 Senior Member
    Aug 11, 2014
    260
    New Hampshire
    You laugh, I could use a parts truck just like that one. You can keep the light bar.
    DMiller likes this.
  10. Truck Shop
    Dec 8, 2015
    3,951
    fry cook
    SE Washington St
    Oh that truck is full of usable parts, its the frame work that is laughable.
  11. 56wrench
    56wrench Senior Member
    Dec 4, 2016
    296
    alberta
    up here, running, drive-it-away w/stars of that vintage would likely be in the $4500 range or less at Ritchie sales. any old trucks of that vintage would be similar, but that being said, I've seen 2 bidders drive up the price of anything. pre-electronic trucks only depreciate so far and hold some value around here because anybody can keep them running as long as the cab is in reasonable shape
  12. Truck Shop
    Dec 8, 2015
    3,951
    fry cook
    SE Washington St
    And some are only worth the tires holding them up.
    56wrench, RZucker and DMiller like this.
  13. JPV
    JPV Senior Member
    Aug 20, 2015
    330
    S.W. Washington
    That sucker would have some bark to it with those stacks, the worst thing about those trucks is that the rear motor mounts are on the transmission bellhousing. Makes it a pain to pull the transmission and I don't know what the point is.
  14. Birken Vogt
    Birken Vogt Charter Member
    Nov 30, 2003
    3,046
    Grass Valley, Ca
    The point is they install the engine/transmission as a unit at the factory before the cab is lowered on and they don't care what happens after that.
    DMiller and JPV like this.
  15. Truck Shop
    Dec 8, 2015
    3,951
    fry cook
    SE Washington St
    Those bell mounts can be a pita, but if you get the engine jacked right and install the clutch on the input shaft with the transmission all at one time it goes fairly easy. But remember Ford, Mack
    White and Gm all used the bell mount. That's another reason I like PacCar Trucks. They were designed and built on the west coast to start with.;) The Stars are good trucks and built out here also but those also
    have their problems.
    JPV, RZucker and DMiller like this.
  16. mowingman
    mowingman Senior Member
    Jul 11, 2010
    551
    north Texas
    Funny there is mention of the engine/transmission here. My son worked at the Peterbilt factory here in town for about a 2 years. His job was to install the transmission in each truck BEFORE it went on to the cab installation area. He always talked about how easy it was to put accessories on the transmission BEFORE it went into the truck.
    DMiller likes this.
  17. Truck Shop
    Dec 8, 2015
    3,951
    fry cook
    SE Washington St
    Like I said if you install the clutch in the transmission {can only be done on 15.5" clutch}. It takes the fight out of it trying to push the input shaft through the plates, especially on
    a transmission that has the mounts on the bell. You just bar the engine over and start and run the bolts down through the inspection cover opening. Below is a example, the only
    thing that has to line up is the input dowel on the end of the input shaft, which lines right up and you throw the bolts to the bell housing then bolt up the clutch.
    JPV, Labparamour and RZucker like this.
  18. crane operator
    Mar 27, 2009
    4,225
    sw missouri
    I've never installed a clutch that way, the bolt holes in the inspection hole probably line up fine, once you get the trans tight to the bell housing?
  19. Truck Shop
    Dec 8, 2015
    3,951
    fry cook
    SE Washington St
    Piece of cake crane operator, first get all the bolts started through the clutch cover to flywheel and have someone bar the engine over and suck them down even and torque them 55 lb Ft.
    The wood blocks keeping the clutch depressed will fall out right as it bolts down tight or push the pedal down and those will fall out. Sometime you have to reach up with a long screw driver and pop
    them out with pedal depressed. Saves your back, frustration and time doing it that way-been doing it that way since the early 80's. Just bolt the bell up tight to start with.
  20. farmerlund
    farmerlund Senior Member
    Nov 23, 2014
    619
    Farmer/ excavator
    North Dakota
    Ok, so you lost me on the wood blocks. Where do they go? We swapped a 60 series Detroit in a kw last winter, and it was a real pain getting the input through the disks. I am thinking it would have been lots easier to do it this way.
    Truck Shop likes this.
