Memories for us old truckers
Discussion in 'Old Iron!' started by Truck Shop, Feb 27, 2017.
  1. DMiller
    DMiller Senior Member
    Feb 22, 2010
    4,685
    Retired
    Were there still any Trailmobile or Fruehauf torsion rides when you got in the business TS? Only ever saw one, Fruehauf and was used for storage at quarry, older mechanic noted Trailmobile also used a set up similar.
  2. RZucker
    RZucker Senior Member
    Jul 7, 2013
    2,537
    Mechanic/welder
    Wherever I end up
    Torsion was even more fun on a hay truck. :eek:
    DMiller likes this.
  3. DMiller
    Feb 22, 2010
    4,685
    Retired
    Swim a tad?
    RZucker likes this.
  4. DMiller
    Feb 22, 2010
    4,685
    Retired
    Truckers in the Quarries preferred the old 38 and 42,000 lb. Hendrickson's. Local here still orders the Suspension, I do not know the model, has V mounted rubber block 'Springs' in the center masts, says ride well enough for Dump truck service.
  5. RZucker
    Jul 7, 2013
    2,537
    Mechanic/welder
    Wherever I end up
    I remember seeing a trailer (flat, I think) with torsion bars, don't remember the make.
    DMiller likes this.
  6. Hank R
    Hank R Senior Member
    May 29, 2014
    1,173
    Retired Truck driver and School bus driver
    Princeton B.C. Canada
    Were torsion bars very common back in the day ???
    DMiller and Mother Deuce like this.
  7. RZucker
    Jul 7, 2013
    2,537
    Mechanic/welder
    Wherever I end up
    They did seem to be fairly common on Kenworth trucks in the 60's and early 70's.
  8. petepilot
    petepilot Senior Member
    Jul 7, 2018
    481
    central shenandoah valley va,
    those things were kw`s own invention
    Truck Shop, DMiller and Mother Deuce like this.
  9. RZucker
    Jul 7, 2013
    2,537
    Mechanic/welder
    Wherever I end up
    Yep, other than a few trailers, torsion bars were KW's own domain.
  10. RZucker
    Jul 7, 2013
    2,537
    Mechanic/welder
    Wherever I end up
    Seasick was a better description.
  11. DMiller
    Feb 22, 2010
    4,685
    Retired
    GM used Torsion ride on the front of the old 60s 2 ton Vikings, did not last long, then the early 90s came back in the pickup line on the 4x4s. I believe the thought was weight factor as well a ride concern but in all eventuality they were maintenance heavy and a PITA to work on. After rebushing my own(took five days after work hours) took me almost a day to get ride height right adjusting the tension on the bars.
    RZucker, Truck Shop and Wytruckwrench like this.
  12. Hank R
    May 29, 2014
    1,173
  13. Old Doug
    Old Doug Senior Member
    Oct 16, 2013
    1,021
    Mo
    They used then on pickups in the 1960-61. I was thinking i saw a GMC craker box with them? Its hard to belive that they didnt build a prototyp and drive it around for a while and say this isnt so hot.
    Mother Deuce, RZucker and DMiller like this.
  14. RZucker
    Jul 7, 2013
    2,537
    Mechanic/welder
    Wherever I end up
    I drove one of those old 60's GMCs fueling equipment for Dad after school, talk about the ball joint boogaloo if you had to drive it on the road. It finally got sold because no front end parts were available. Had one strong running old V-6 in it. I do remember the hydrovac brakes making you plan stops well in advance.
    It ended up getting sold to another outfit and I actually got the job of putting the tank and pumps on a later Ford C series cabover with a 3208 Cat and an Allison 643, turned out really nice.
    Mother Deuce and DMiller like this.
  15. Hank R
    May 29, 2014
    1,173
  16. Truck Shop
    Truck Shop Senior Member
    Dec 8, 2015
    1,936
    SE Washington St
    I like that Star in the upper photo! Here's another to go with it. That's when Stars were Stars.
  17. Wytruckwrench
    Wytruckwrench Well-Known Member
    Jul 23, 2012
    236
    Wyoming
    I have an ‘85 Star like that. I never have put my log riggin on it yet. If the log haulin market comes up again I will.
    Truck Shop and DMiller like this.
  18. Truck Shop
    Dec 8, 2015
    1,936
    SE Washington St
    A place I worked at years ago D & M towing had a 1978 Star with a NTA 420, 13sp and two spd Eatons on 48,000 lb Hendrickson extended leaf, with a Holmes 750 and a 301 Zacklift.
    Here is a nice Star that was used in the movies.
  19. Hank R
    May 29, 2014
    1,173
  20. Truck Shop
    Dec 8, 2015
    1,936
    SE Washington St
    And a PeterCar logger.
