Mechanical Gooseneck and a new way to make it easier.
Discussion in 'Trailers' started by Chaz Murray, Aug 29, 2011.
  1. Dualie
    Dualie Senior Member
    Feb 24, 2007
    1,371
    Nor Cal
    I have latched the wagon in some pretty dumb spots. But the best idea no matter what style of lowbed your running is to not drop it in dumb spots. Hard level ground is always your best idea. I have picked up a a loaded wagon that had over 38,000 Lbs on the kingpin without any problems at all.
    You do have to get in and out of the truck 4 times if your doing it with a truck with no air release 5th wheel. But after having run Both a Non ground bearing and a ground bearing Hyd detach i would trade my Murray mechanical for any other lowbed period.
  2. monster truck
    monster truck Senior Member
    Nov 14, 2008
    267
    cali
    I have ran a truck that had long enough lines to drop the neck without disconecting them. I tended not to do it much though because it would get them covered in grease when they laid across the fithwheel.
  3. Chaz Murray
    Chaz Murray Well-Known Member
    Oct 26, 2007
    215
    Stockton CA
    Don't think we did not think about that! ;) Just figured it would be cost prohibitive so just left it the way it was for the air and electrical. There is a point where you need to draw a line in saving time and cost...I think that was the line that we found ;)
  4. Dualie
    Feb 24, 2007
    1,371
    Nor Cal
    Whats another $1500? The way i look at it is one less trip in and out of the truck is one less chance some crazy 4 wheeler has to put me 6 feet under. Or one less chance i have to bust my azz with muddy boots.
    is this option retrofitable to older Murray wagons or do you have to buy a new wagon designed for the feature?
  5. Exact Express
    Exact Express Active Member
    Jan 23, 2010
    40
    s.e. michigan
    All I'm saying is that there are times I can't get hooked to an empty trailer in my yard in the winter, because of the snow and ice. I guess everything has it place. As for getting in and out of the truck, I could get away with one trip, but I make it two. I get out, unchain, then get back in to turn on the hydro's. I like to unchain before breaking down, had guys jump in the machine and fire it up while I was still taking the chains off.
  6. Dualie
    Feb 24, 2007
    1,371
    Nor Cal
    i have never had to load in the ice so im not going to comment. Probobly why these are CA legal 16 tire wagons. I don't think i ever care to find out what works in the snow and ice either.
    But i do know they use the hell out of the Murray and cozad mechanical detach wagons in the Alberta oilfields and logging all winter long. Even up the winter roads in Alaska they have them
  7. Chaz Murray
    Oct 26, 2007
    215
    Stockton CA
    Yes it can be retrofitted to an older trailer.
  8. Sparkie
    Sparkie Well-Known Member
    Aug 4, 2011
    50
    Cyrus MN
    The guy in the video got out 4 times with a air release 5th wheel... I don't know. Still just doesn't seem practical for normal use. If all you were dropping on was hard pack dirt or other hard surfaces maybe. I'd personally like to see a demonstration in the dirt. I think the angle only seems so bad because the truck is aired up and the bags aren't dumped. I feel like its really a perfect conditions only system.
  9. Per Eriksson
    Per Eriksson Senior Member
    Oct 24, 2007
    533
    Sweden
  10. Dualie
    Feb 24, 2007
    1,371
    Nor Cal
    besides the fact they are heavy, slow, and require far more complexity and things to go wrong that the mechanical detach. Oh only about 100 more reasons.
  11. StanRAUUS
    StanRAUUS Member
    Sep 24, 2011
    21
    S.Cal USA - Wien, Austria
    The Air Eject HP as currently designed would be very restrictive air volume wise! Designed to keep systems charged with air during stand-by.
