Mech Detach Neck too low??
Discussion in 'Trailers' started by Andrew_D, Apr 19, 2014.
  1. Andrew_D
    Andrew_D Senior Member
    Oct 20, 2012
    297
    Newdale, Manitoba, Canada
    Well, we missed a couple of trailers today.....
    Dad was watching an online auction but had to step away from the computer for a bit when he came back the 2 trailers were already sold.
    1) Tandem axle lowbed. 30ton, so not huge or anything. Sold for $6,000.
    2) Move-All. Hydraulic tail. Tandem Axle. Sold for $4,000.
    I told him he should have bought them both and re-sold 1!
    Andrew
  2. 1466IH
    1466IH Senior Member
    Feb 5, 2014
    281
    prairie du rocher, il
    Yea it was the owner of the company's first truck and trailer. Used to haul around a straight 580. Nice trailer though it was a hydraulic tilt and about the only thing it ever gets used for anymore is hauling around rollers and miscellaneous materials. I don't know what year the stuff was but it was a gas truck with a 5+2 trans/rearend. I was green as could be. The trailer didn't even have air brakes. They were vacuum. The trailer was backed into a shed so there was no way of pushing. All they did was cut the huck bolts holding the 5th wheel on with a torch then pulled the handle and drove it to the shop and put new bolts in so it wasn't that big of a deal but I thought it was at the time. It was my first job in high school right after I started so I was a little nervous when I had to go ask what I did wrong
    Sent from my SAMSUNG-SGH-I317 using Tapatalk
  3. Bluox
    Bluox Senior Member
    Jun 20, 2010
    695
    WA state
    I bet your'e looking at a scissor neck float.
    Bob
  4. Andrew_D
    Oct 20, 2012
    297
  5. RZucker
    RZucker Senior Member
    Jul 7, 2013
    4,009
    Mechanic/welder
    Wherever I end up
    Just curious, but dont most of the old school oilfield winch trucks have the 5th wheel at the rear of the frame? I remember seeing a few like that, I think.
  6. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Yeah RZucker , 5th wheel just ahead of the tailboard . Helps prevent truck frame from binding with trailer in off road conditions .
  7. RZucker
    Jul 7, 2013
    4,009
    Mechanic/welder
    Wherever I end up
    That could explain the short gooseneck.
    By the way, Cool truck you got there td25c. Read the thread awhile back.
  8. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Thanks RZucker . Still got a few odds & ends to add to the truck but she is pretty near complete .
    From what I can tell the Scona trailers look purpose built for oilfield & rigging . The more I think about it if I was looking at that type of trailer I might just go with the winch & tail roller arrangement on the tractor & leave the trailer as is .
    Something like these tractors www.truckpaper.com/listingsdetail/detail.aspx?OHID=5005715
    www.truckpaper.com/listingsdetail/detail.aspx?OHID=4941631
    www.truckpaper.com/listingsdetail/detail.aspx?OHID=4265237
  9. handtpipeline
    handtpipeline Well-Known Member
    Mar 29, 2008
    209
    Utility Contractor
    Sperry, OK
    With the rolling tailboard on it, it was definately designed and built to be pulled by either a winch truck (bed truck or rigup truck. I've heard several different names) or a winch tractor. With the short neck, probably a bed truck. They work good, but for moving equipment you better have a really stout winch (Tulsa 64 or prefferably Tulsa 80), and run it off a power tower. I stripped a bull gear and blew the PTO off the side of the transmission trying to winch a dead track loader up the dovetail of a lowboy once... It was a Tulsa 34. And we had lifted some pretty good loads with it previously. 2 Case 580 backhoes or a 580 Case and 450C JD sideboom on a 40' float. Or you can run your equipment back over the tandems, lift and hook up, then move your equipment to where you need it to haul it. We used to do that when hauling a sideboom on the floats. Did it many times with TD-14 and TD-18 sidebooms. Tried hauling one of the D-7"s on a float once... Ended up re-building the float when we got it back to the shop... But loading and unloading that method worked fine...
  10. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    That makes sense handtpipeline :thumbsup What you call the "Power Tower " , is that a reduction box between the winch & pto drive ?
    When I set up the FWD winch truck we installed a reduction box between the pto & winch drive . My pto is a Tulsa brand two speed reversing unit and the winch is a Garwood . It's geared pretty slow . http://s1016.photobucket.com/user/td25c/media/100_2807_zps030d0791.mp4.html?sort=3&o=5
    First wrecker I operated had a Tulsa 100 behind the cab . Old International B 2000 with home made bed . That Tulsa would sure pull :)
  11. Heavey Metal
    Heavey Metal Well-Known Member
    Sep 14, 2013
    148
    Texas
    A power tower is a pto that mounts to the top of a spicer auxiliary transmission.
    Allows you to change speeds with the main transmission.
  12. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
