Exactly! Most major advances are made by us misfits, one way or another, lol!Some times you just got to give a lash at things yourself even if they may be a bit mad (not saying this idea is)(more my own).
Good for the soul
I've never been able to run hard face out of position and make it look good. When doing sides of something I've either accepted that it will look like crap or I took the subject off the machine and turned it so that I was welding flat.
I Hardface with wire its a challenge to to the sides its easier to cheat and put on a piece of ar or the little wear blocks if you do have to buy hardface supplies talk with your professional welding store about your application as there are so many different types time and money to be lost using the wrong product
I didn't catch what size rod you had but the spec sheet shows only flat over 1/8 inch
https://mam.esab.com/assets/1/BDBA5...E71D60CC5/V410011-en_US-FactSheet_Main-01.pdf
I like your tire sipes also
On our 966c Loader it has some hardfacing thats lasted the test of time. The beads on it must be 3/4" x 1/2" thick! I'm not sure what they put it down with but must have been a monster welder.Years ago I ran some rod that was acceptable for downhand passes, but then I was running a Miller Big 40 at the time. I sincerely regret ever selling that big mother, smoothest DC stick machine I've ever run. Customer told me later my hardface lasted longer than the previous guys, I just wish I remembered what brand and number that rod was!
I like the picnic bench 2. Getting sick of perching on rams an bosses
The edges always wear out so fast, I put these extra wear plates on, now I can get another season out of the same edgeWhat’s the steel on the end of the edge for ? Is the main edge flat or rounded from wear?
