Make sure ya'll are using Bonded Fuel Hoes on transfer tanks
Discussion in 'Safety Issues' started by Dozerboy, Sep 8, 2013.
  1. Dozerboy
    Dozerboy Senior Member
    Jan 18, 2006
    2,205
    Operator
    TX
    I know diesel ain't going to burn off just a spark, but better safe.
    We had a guy report he was getting shock while pumping fuel. We check out the wiring. It was fine. It came up again that people where getting shocked. It turned uot we had a non bonded hoes on the pump and the static build up was arcing from the nozzle to what we where fueling. We have a good vid of the arc have to see if I can get and post it.
  2. clintm
    clintm Senior Member
    Jul 8, 2013
    974
    charlotte nc
    I have noticed that the new ulsd fuel is thinner and there seem to be more hwy trucks catching on fire in wrecks.i think the flash point is lower. it also seems to evaporate faster and does not leave as bad of smell on your clothes or hands. has any one else noticed this.
  3. Dozerboy
    Jan 18, 2006
    2,205
    Operator
    TX
    Diesel has always have a pretty wide range for a boiling point ETC. I think after all these years of ULSD this is peer speculation, but...
  4. FSERVICE
    FSERVICE Senior Member
    Apr 3, 2009
    635
    indiana
    i spent a few years working for a propane company as a service man on dispensers like at KOA, U HAUL,few others. static electricity is really bad stuff, its amazing how slow motion video can catch the spark jumping from pants leg to a hose to ignite a fire that the guy there swears just started outa nowhere!! (there was a small gas leak at the valve connection to provide the gas) The less humid it is the worse it gets also. just make sure everything is grounded good with the right ground clamps/rod;)
  5. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Not a bad idea Dozerboy. Aircraft are grounded with a cable & clamp before fueling to prevent a spark. Funny story.... My buddys John Deere 755 high lift blew a hydraulic hose when he was working under a high voltage power line.I had the batteries removed from the machine & it was very hot that day so I was covered it sweat . Whenever skin would come in contact with the machine I would get a good jolt from what I assume was the static electricity from the power lines.
  6. FMD
    FMD Well-Known Member
    Jul 26, 2013
    83
    somewhere
    Do you have a photo of your bonding technique for your nozzle? All of our 55 gallon drums are bonded, but our UST fuel dispensers are grounded. From my understanding if the dispenser is grounded properly (NFPA 407..<10,000 ohms) you wont get static except from the static from the person NOT from the dispenser or nozzle. I know when I worked with GSE at the airport, they had ALL of the GSE bonded AND grounded on fueling.
  7. Dozerboy
    Jan 18, 2006
    2,205
    Operator
    TX
    The nozzle is grounded through the use of the proper hose ideally, or you run a cable to ground/nozzle/tank.
  8. oldtanker
    oldtanker Senior Member
    Sep 26, 2010
    463
    Ret
    vining mn
    Wanna bet that it wont? I know of 2 cases where it did result in an explosion and fire with diesel. One was in a motor pool in Mannheim Germany. Improperly grounded fuel tanker went up. Kid on top the tanker was lucky and had minor burns and a broken hip. The 2nd one was just a couple of weeks later at Ft Knox, another tanker, government civilian employee on top the tanker when it went. Again improperly grounded, the blast threw the guy into the air. He came down on a fence and died of his injuries. In both cases the tankers had pumped 1,000s of gallons without being properly grounded and had huge static build up. Both places were hot and unusually dry when the tankers went up so fumes and dry air played a factor.
    Rick
  9. Catpower
    Catpower Well-Known Member
    Sep 23, 2006
    52
    Electrician, equipment operator
    Prince George BC
    td25c you are correct on the induction working under the power lines. I will have to measure my hose and see if it is bonded, I don't pump much fuel off just to the trucks tank so figure I won't get too much static buildup?
  10. ValleyFirewood
    ValleyFirewood Senior Member
    Aug 17, 2013
    311
    Palmer, AK
    Bonded "hoes". Sorry but I just had to laugh!
    I'm just picturing a girl working a corner and "customers" pulling up and asking is she is licensed, bonded and insured.
